1994 Zenith TV blowing fuses - Televison & Video
    Problem Solver:
  • 4 Answers
Change it
Posted on May 05, 2010
1994 zenith no power light how to fix
Most often, a fuse on the set mainboard has blown. You need to be very careful because there can be allot of stored energy in a CRT type television....on the order of tens of thousands of volts. The fuse will be inside near the power input.
My advice is to not open up the TV unless you are experienced. The voltages inside can kill or seriously injure.
The bad news is that this fuse ususlly blows when the sets "flyback" transformer goes bad. This is not a simple item to replace and you should take the set to a good repair shop and get an estimate to see if the set is worth fixing.
Feb 14, 2011 | Zenith Televison & Video
Every time i change the fuse it blows up
You have a shorted Horizontal Output transistor and a bad capacitor or two. Look for a bad resistor and you may have a bad flyback transformer [rare]. But yes the transistor is down!
Apr 11, 2010 | Zenith B25A02Z TV
Plug in no power
Check the fuse inside the TV. If fuse blows, there is a problem elsewhere.
The initial spark you are mentioning is due to degaussing coil. This is not routed through fuse.
Apr 07, 2010 | Zenith A36B41W 36" TV
FUSE BLOWS EVERYTIME I PLUG THE TV IN
change the horizontal output transistor
replace fuse with exact #
repairs must be done by a qualified tv repairman
Dec 02, 2008 | Zenith B25A74R 25" TV
ZENITH BLOW`S FUSE
you have a direct shot in the power supply check the rectifier diodes (4 of them) or check for shorts to ground other components. check the HOT for short between emmiter and collector, and base and collector.
Feb 02, 2008 | Televison & Video
Power Button
there is a line fuse inside the set should be a 4 amp, could be blown and if it would blow again you have a short on the board. (if u r to try it don't forget to unplug tv!)
Oct 29, 2007 | Zenith C27A24T 27" TV
FUSE BLOWS EVERTIME I TURN MY TV ON. I CAN REPLACE THE FUSE AND DISCONNECT THE FLYBACK FROM THE CRT,TURN THE SET BACK ON ,CHECK THE FUSE IT WOULD STILL BE GOOD,BUT WHEN I REINSERT THE FLYBACK AND TURN THE...
Possibly a resistor that's becoming defective... it's changing value thus increasing current. like if the resistor has a rating of a 10k Ohm and now it's changing to a 30K Ohm and the current (amps) is supposed to be around .50Amps and now it's rising to .75Amps or higher, so it would blow the fuse so as not to further damage any other high voltage or sensetive component. Is the fuse you are replacing the same as rated for the tv? ie; 250V 1.25Amp FB (fast blow) or SB (slow blow) it should say on the circut board where the fuse plugs into.
Jul 17, 2007 | Zenith C27A24T 27" TV
IQC50H94W Zenith Projection tv
check the flyback/hv-spliter sounds like it could be your problem also check horizontal ic
Jan 23, 2007 | Zenith IQC50H95W 50" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
