Question about Sharp Televison & Video
My TV Sharp 26 SB1 LCD PBS channel breaks up
My Sharp 26 SB1 LCD over the air signal gets all channels fine but 1/2 the time New York channel 13, the PBS station breaks up badly. Tried differnet antennas and different locations with same result. Other TVs in the house do not have the problem.
  • allenhinman May 02, 2010
    only very weak distant OTA channels have any problems. Tried different antennas, different amplifications, other TVs other channels all fine, fine on the Sharp 40% of the time, 60% channel 13 breaks up. Moved location of TV in house, same results. Did the reset, nothing happened, scanned channels stayed up. Eliminated 13, rescanned channels, same result.
    Thanks anyway.
  • Sharp Master
  • 5,187 Answers
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
Posted on May 01, 2010
  • Cindy Wells May 02, 2010
    I wish that I could be of more help. Since it is intermittent and a distant channel, I'd suspect interference from weather or aerial traffic (birds).
    My TV where the reset worked was having trouble with the closest station (~15 miles) when the outdoor aerial was pointing straight at the station. Thus it had a totally different issue.
I can no longer receive channels # 4 and # 38 (in Boston), after attempting to reprogram the channels. Why?
In my area, I can't watch anything on CBS, NBC, and some PBS channels even though the transmitters are in Philadelphia and I'm right across the Delaware River in New Jersey. You can try experimenting with antenna orientation or a different antenna or adding a signal amplifier as well as frequent rescanning but results are likely to continue to be disappointing.
Oct 23, 2016 | Samsung Televison & Video
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
Jul 09, 2010 | Sharp LC-32SB21U 32 in. LCD TV
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I just purchased an amplified indoor HDTV Antenna to better receive HD tv. Is the LCD display supposed to be on all the time??? How can I get better reception from a broken picture even rotating the...
I don't know in what area you live & therefore how strong your reception area will be, but as a general rule an indoor antenna is never the best type of aerial to have to receive digital signals, you will always find that you pick up some good strong channels but more often the rest of the channels will be poor or non-existant & will constantly break-up/freeze etc. The best advice would be to try & fit an outdoor antenna if possible.
Jul 15, 2009 | Televison & Video
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv guide/tuner problems
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Dec 25, 2007 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
171 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
