Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
On a 2-cylinder, 25 hp Briggs & Stratton INTEK twin engine (year 2002, Model 44577-0134-E1), there is a ~1.5-inch rubber hose to the top of the right OHV cover coming down from a round plastic piece in the fuel line. It is cracked and torn where it is attached to the OHV cover. Questions: What is the purpose of the hose and how do you replace it? Thank you for your assistance.
  • dwkurz May 01, 2010
    Yes, it runs when the remnant of the hose is attached. When not attached, the engine will stall after a minute. Must be a fuel pump. I guess I need to pull the valve cover to replace the rubber fitting that is torn. Does this make sense?
  • 661 Answers
Ok I haven't worked on this exact model before but Im curious if the engine runs?
It sounds to me like a fuel pump that uses crankcase pulses to pump the fuel. It is very common way to pump fuel but usually the pump portion is in the carb and not the fuel line.
If it were attached to the intake Id say it was a crankcase breather.
Posted on May 01, 2010
Testimonial: "Thank you!"
  • Bryan Fullerton
    Bryan Fullerton May 01, 2010
    Yeah it makes sense. the tear must not be too bad though if it still runs. replacement is the best solution though. Id say it is indeed a low pressure pulse fuel pump. I think you will be all set with a new one. Taping it up might be a temporary solution if the engine seems to starve for fuel under load.
    Have a great weekend.
That hose sends air pulses to the fuel pump to pump fuel from the tank. If it is cracked, the fuel pump will not work correctly. The parts illustrations for B&S **** so you should take the remnamt to an auto or tractor shop to get a replacement. Short term, duct tape might get you cruisin' the back 40.
Posted on Apr 11, 2012
Battery is not charging. Does the Intek V Twin have an alternator and voltage regulator?
Yes, to both. Plug the model number in the searspartsdirect.com and you can get the parts listing & part numbers..
Oct 28, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Does the exhaust vavle have a stem seal on a intek twin cylinder?
Most do not. Check your exact model/type/code numbers on the parts lookup site here.
Sep 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Bent push rods both cylinders,engine # 445677-0827-B1
You can find a manual, free of charge at www. briggs & stratton.com. click on manuals and put in your model and type and its free to d/l. You can then print it out if so desired.
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,876 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
