Question about Toshiba 32A33 32" TV
Toshiba 27A40 has single colored line across enter
Toshiba 27A40 has a single colored line across enter of screen, on a black screen - some times it goes away and has a full-screen picture - but it happens more often now. Is this big $$$$$ to fix???
    Sergeant:
  • 418 Answers
Vertical output has cracked soldering. Around $150 to fix.
Posted on May 02, 2010
I have a Vizio M701d-A3 with single line across the top half of my screen, it appears over top of the menu when displayed. The line is not black but changes color with the picture. What's the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Projection TV no picture flashing horiz arcs across top of screen sound okay
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting.
This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
Jul 24, 2014 | Toshiba Televison & Video
Cant get rid of horizontal lines on my prinying pages,ive tried re a lignment but doesnt work
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem:
- Replace the ink cartridge
- Check the flexible cabling for continuity and for short circuits between adjacent conductors
- Exchange the control board for a good one
- Finally check the power supply
Good Luck
Mar 09, 2011 | Epson Stylus 880 InkJet Color Printer
Despite inserting new black cartridge (Brother LC57 BK), print is faint and on spreadsheets is blurred and has horizontal lines across pictures.
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem: - Replace the ink cartridge - Check the flexible cabling for continuity and for short circuits between adjacent conductors - Exchange the control board for a good one - Finally check the power supply
Good Luck
Mar 09, 2011 | Brother MFC 210C All-In-One InkJet Printer
I have a CF3062A. Picture has collapsed into a
In the old days that means your "flyback transformer"needs to be replaced.
Take it to a TV tech or junk it and buy a new one. That might be cheaper.
Jul 19, 2010 | Toshiba Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Screen is black wiht a single 1/8 thick horizontal line across entire screen. Sound is ok. Other TVs are working.
cold solder in vertical ic and check caps around to..if you see resin around any cap, change.
Apr 22, 2010 | Toshiba CF32H40 32" TV
Our Toshiba HD tv has gone on the fritz. Every so often when we turn it on their is a single line across the middle of the screen, the rest is black. you can hear the program that the TV is tuned to. Any...
The vertical output ic needs re-soldered, look for a 5 pin ic connected to a heat sink near the flyback, re-solder the pins. If you are not up to this a local shop should be able to do this and it should not be an expensive tv repair.
Sep 02, 2009 | Toshiba Televison & Video
TOSHIBA 27A40 TV
Good day.
if your remote is not responding to your tv and you were able that your remote is good, then there must be a problem with your tv.
I suggest that you have your unit be checked by a repairman. No matter how many remotes you buy, if the problem is within your tv, it will not be resolved.
chris
Mar 25, 2008 | Toshiba 27A40 27" TV
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Toshiba 32A33 32" TV Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
