Question about Sharp AR-235 Copier
Display panel h4 code any clues?
Copier was printing having paper jams then err fax / copier check display panel h4 not
nothing happens bootting not in the machine my email (sergiobece01@gmail.com) Help
  • 231 Answers
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
Posted on May 03, 2010
Testimonial: "Sure was perfect h-4 Heater element or thermistor Thank YOU for the AR-207"
How can I clear H4 on AR-M 150 3 in 1 sharp
Posted on Jul 10, 2011
  • enimgbo2 Jul 10, 2011
    Display solution for AR-M150 error code H4
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
My printer is now 2 years old. Always done great, nothing happened. But now he can't get the A4-paper out of the tray. He trays to grab the paper, but it doens't work. Photo's out of the photo-tray is...
Looks like you have a paper jam problem.Pieces of paper are stuck in the roller.Go to Control Panel ->Printers and Fax -> Select you printer and click properties.You will find a Printer Maintainance Wizard,which will have a paper jam clearing wizard.Click this and your printer will work as good as new.
Thank You.
Feb 20, 2011 | HP Photosmart D7160 InkJet Printer
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Digital Copier AR 5316E error code H4 indicating
An H4 code denotes a low temperature or temperature sensor failure problem with the fuser (the device that provides heat and pressure to bond the toner to paper). There may be a peice of paper or part of a peice jammed up inside the fuser that's blocking the sensor, or the fuser is defective and needs to be replaced.
Sep 18, 2009 | Office Equipment & Supplies
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Paper jam
I have had this problem, and have became very furiated.
Clear the Jam by removing and paper you see in from the rear access door.
If you are printing something from a PDF website....... make sure to have it still in the printer schedule.... It will still say printer jam..... but have it there regardless if its something you dont want to have to retype into the pdf form........ After that simply restart your computer. It should resume printer as soon as your computer boots up.....
Worked for me..... Hope this helps everyone else whos probably cursing your printer at the moment!!!!
Mar 22, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Kyocera CS 2030 fax jams
Hi,check settings for fax.Try to check paper attributes for fax.Maybe You have different paper format adjusted for fax printing.
Oct 19, 2007 | Copystar CS-2030 Copier
Sharp AR-235 Copier Logo
173 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
