Question about GE 18023 Dimmer Rocker OnOff with Slide White
3 way dimmer in a single switch ap
Just bought this dimmer and now I notice that it is for a 3 way application. Can this dimmer be used as a single position dimmer switch?
  • czeiler May 02, 2010
    According to the instructions, the GE 18023 3-way dimmer can also be used as a single pole dimmer. There is a red tag on one red wire with instructions not to use when the dimmer is used in a single pole application.
    The instructions state that if the GE 18023 3-way dimmer can be used in a single pole application, simply do not use the red wire that has a red tag attached.
    Novelist:
  • 145 Answers
Sometimes it can sometimes it can't. They make dimmers designed for both. If it is not designed for both it can only be used in a 3 way application.
Posted on Jun 11, 2010
How to fit dimmer switch
The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
May 29, 2013 | Electrical Supplies
Leviton 6793 does not work on LED lamps?
Look at product number again to see if numbers posted are correct.
Also include what type of device this is: rotary dimmer? slide dimmer? touch dimmer? Switch? single-pole application or 3-way? And include what you are replacing.
Aug 06, 2012 | Electrical Supplies
Installed Acenti by Leviton single pole switch and when in "off" position, there is a flickering of light on and off, its like a pulse... model AC201-1LW... the only thing i can think thats wrong...
No you are getting a backfeed from somewhere else...either the neutral is no connected properly or you have a bad ground...
It has nothing to do with the amp. rating of the switch..
heatman101
Apr 23, 2011 | Leviton Acenti AC201-1LW 20 Amp, 120VAC,...
My GE lighted rotary dimmer switch has 3 wires coming from the same hole- 2 black and one red. Is the red wire the ground wire?
No.
It is most likely a three way dimmer, where the two black wires would run to the other three switch, and the red wire would either run to the breaker panel or the light fixture (depending on the electrical box location).
If you're using this in a single-pole application, place a wire nut on one of the black wires, and then wire it as a single-pole device using the red wire and the remaining black wire.
And make sure you have the power turned off before attempting.
Jan 26, 2011 | General Electric Ge Deluxe Lighted Slide...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
I'm using a Cooper Master Dimmer with a Cooper toggle type 3 way switch circuit controlling one incandescent light fixture. My home is 30 years old and I've found many deviations from acceptable wiring...
The problem is most likely not the dimmer or the wiring, but rather the existing 3-way switch.
First of all, the Aspire smart dimmer does not work in conjunction with traditional, 3-way, on/off toggle switches. When the 3-way switch is in one-position, it lets the dimmer work, but in the other position, it cuts power to the entire lighting circuit - and the smart dimmer is NOT going to be able to override that. You instead need to get the corresponding remote dimmer (sometimes called a slave, or a companion dimmer), and use that to replace the standard 3-way switch.
That may also solve your "mystery turn-on" issue. Even though those dimmers can use the existing 3-way switch wiring, you have to REALLY pay attention to the instruction sheets to see how the master and the slave wire up to each individual electrical box. I vaguely remember that even if you were to use the product in a single-pole application, those two wires that, I assume, you attached to the traveller wires in the house needed to be shorted together in order to work - and since you have them running into a 3-way switch, the errors that you're seeing are bound to happen.
Long story short, get the slave dimmer, install it according to the instructions, and all these problems should go away.
Nov 09, 2010 | Cooper Wiring Devices Aspire Smart Dimmer...
I have 600 w lutron dimmer running 3 40 w incadesant lights. they start blinking like strobe lights. change bulbs and it goes away
If your dimmer was working correctly in the past, and suddenly started doing this, then your dimmer is probably gone bad.
If this is a new installation, the wiring could be wrong, or the dimmer could be wrong.
For example you purchased the companion or accessory dimmer rather than the main dimmer.
Or the wiring is put on the wrong screw.
If this is a new installation, add a comment and fill in the information and I can troubleshoot.
What is the model number of your dimmer.
For example the Maestro MIR600.
Are you replacing a single-pole switch or a 3-way switch?
Are you using 2 dimmers in a 3-way application?
What color are the screws on your dimmer?
What color are your wires and which screw do they go to?
Nov 04, 2010 | Lutron Electrical Supplies
I only need a single pole dimmer switch. Which product do i buy. I bought the smart dimmer system remote, but it doesn't seem to be right.
The photo shows the master 'smart' dimmer, but you purchased the remote 'smart' dimmer that is slave to the master dimmer.
So you are correct, that is not the correct dimmer for a single-pole application.
Cooper brand Aspire dimmers are available in 'Smart' dimmer and just plain old dimmer.
Smarthome has a plain old aspire dimmer
http://www.smarthome.com/21530S/Aspire-9530DS-600w-Slide-Dimmer-Desert-Sand/p.aspx
Google products also shows the Lutro Maestro dimmer
http://www.google.com/products/catalog?q=maestro+dimmer
Lowes and Home Depot have ordinary dimmers also.
Both the dimmer linked to above will work for your single pole application. Keep in mind, they also work for 3-way applications so there will be an extra wire.
Since you know the phrase 'single pole' I suspect the wiring for you will be a cinch.
If you need assistance with the new dimmer, add a comment and I will answer.
Oct 30, 2010 | Master Heaters Aspire Design System Smart...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
I have a dimmer switch where there is two balck wires and one red wire needing to go into it. I have out the red wire onto a screw on the bottom right side of the switch, a black onto a screw on the top...
It sounds like you have a 3-way dimmer for a single pole application. On the dimmer there should be two screws that are the same color and one screw that is a different color. This dimmer is designed to go on the power end of the 3-way so your power in (two black wires) should go on the one screw that is the different color. The red wire should go on one of the two similar colored screws. If you are already set up this way, change the red wire to the other screw that is currently not being used. The way a 3-way switch works is that the different colored screw (usually black) touches one of the similar colored screws (usually gold) in the down position, and the other similar colored screw in the up position.
Oct 17, 2009 | Lutron Almond 600w 120v 3-way Skylark...
GE 18023 Dimmer Rocker OnOff with Slide White Logo
138 people viewed this question
Top GE Electrical Supplies Experts
Steve
Lawrence Oravetz
robert
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
