Question about Philips TP3284C 32" TV
Model # TP 3284 C101
My 15 yr old son must have altered the parental code and turned off the smartlock.
When I go to enter the code it won't accept a number at all.
Tried a bunch of things and no luck yet. Anyone??
PS. He comes home at 3pm....Help :p
  • 2,337 Answers
Try the instructions found in this link for removing or activating the smartlock.
Posted on Mar 25, 2008
SOURCE:
How do i reset my parental pin
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset
OK.
Jun 28, 2011 | Philips 50PF9956 50 in. HD-Ready Plasma...
Have Sansui @0" tv/dvd/vcr combo that my son locked the parentals control
this problem need a technical assistance from any professional to service your unit to reset and by pass the codes..
Mar 20, 2008 | Sansui DTV2760 27" TV
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
I have accidentally turned the child lock on and then turned of the tv and when i switch it back on it comes up locked on the screen and none of the buttons respond and i do not have the remote controll...
Get a Magnavox (or Philips, same company) brand universal remote and try this. I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set), so I don't know if really a solution.
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 12, 2010 | Philips 28PW6305 28" TV
I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
Mar 05, 2010 | Philips MS2730C 27" TV
Locked tv
Unplug the unit for 5 minutes... After you plug it back in try to power it up. If it won't power-up it's not the result of any lock feature you have another problem... If it powers up and Smartlock is on try this:
The entry code for AutoLock (Magnavox SmartLock) to reset the password code number is 0711 twice.
However, if 0711 is entered just once, the response to first time will be "INCORRECT". If the word INCORRECT is allowed to time out then the second entry of 0711 is not accepted.
To avoid this response when the first 0711 responds with INCORRECT, Immediately enter 0711 a second time. It will then ask for the new code.
Enter the new code and confirm it (2nd time) and proceed to set the blocking as desired.
If you want to purchase a remote for it try here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m1=27ms343s&uuid=12091926696600
Good Luck!
Bill
Apr 26, 2008 | Philips Magnavox 27MS343S 27" TV
Smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Oct 10, 2007 | Philips Magnavox 27MS343S 27" TV
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
New Used tv
Yes there is my friend! Follow these instructions and it will work for you! Philips and Magnavox: Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jun 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips TP3284C 32" TV Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
