Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
How to charge when away from computer.
How do you charge a ipod shuffle when a way from computer
You can buy an iPod charger that fits into a wall plug
Posted on Mar 25, 2008
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
How do i download songs to my iPod model no.A1204 EMC no. 2125? and how to charge it?
As with all iPods, you must use Apple's iTunes application to sync your music with your iPod Shuffle.
You'll need to install the latest iTunes by downloading it from Apple click here> and then installing it. You install iTunes like any other downloaded program by double-clicking on the resulting icon after iTunes has successfully downloaded.
Follow the on-screen directions to install iTunes.
Once iTunes is installed, start up iTunes and have it search your computer for music for it to manage for you. While that is going on, plug the white USB cable that came with your iPod into your iPod Shuffle and into one of the USB ports on your computer. This will trigger iTunes to recognize your iPod Shuffle and ask you whether you want to set it up with this computer.
Follow the on-screen prompts to sync your iPod Shuffle with your computer.
To charge your iPod Shuffle, just keep it plugged in to your computer using the supplied white USB cable. Keep the cable connected until the battery indicator on the ipod Shuffle shows that the battery is full.
Thanks for using FixYa and Happy New Year!
Jan 03, 2011 | Apple iPod shuffle MP3 Player
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    I Pod shuffle (2nd. generation) won't hold a charge
    Hold in the play button for 10 seconds to reset. If that fails:
    iPod shuffle Software Update and Restore
    Apple periodically updates iPod shuffle software to improve performance or add
    features. It is recommended that you update your iPod shuffle to use the latest
    software.
    You can choose either to update or to restore the iPod shuffle software.
    If you choose to update, the software is updated, but your settings and songs are not
    affected.
    If you choose to restore, all songs and data are erased from your iPod shuffle. All
    iPod shuffle settings are restored to their original state.
    To update or restore iPod shuffle with the latest software:
    1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
    has the latest software for all models of iPod.
    2 Double-click the software install file and follow the onscreen instructions to install the
    iPod shuffle Update.
    3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
    opens.
    If you’re using a Windows PC and the iPod Updater application doesn’t open
    automatically, you can find the updater by choosing Start > All Programs > iPod.
    4 Follow the onscreen instructions to update or restore iPod shuffle software.
    If you use the iPod Updater application and it doesn’t see that iPod shuffle is
    connected to your computer, turn iPod shuffle off and turn it on again.
    Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
    Charging ipod shuffle
    WE DID NOT HAVE THE POWER ON IPOD OFF. THANK YOU
    Dec 30, 2008 | Audio Players & Recorders
    My iPod shuffle will not charge
    If iPod shuffle won’t turn on or respond
    â If the status light blinks orange when you press a button, the iPod shuffle buttons are
    disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
    blinks green.
    â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
    battery may need to be recharged.
    â Turn iPod shuffle off, wait five seconds, and then turn it on again.
    â You may need to restore iPod shuffle software. See “Updating and Restoring
    iPod shuffle Software” on page 26.
    Jun 25, 2008 | Apple iPod shuffle MP3 Player
    Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
    47 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
