Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Smells like burning
I turn the vacuum on and withing seconds smell burning. That is without the handle, the actual brush that we use for vacuuming. That is not connected so it is not the roller, or the rubber band that holds it. I has to be the motor. Coincidentally, I just put a new bag in, and I used an off brand, but it fits and it does not seem to be coming from there. It is not making any odd noises.
We had this same issue. I noticed it smells like burning plastic. I took it apart and did not find any fundamental problems. Ball bearings on motor are fine, no play. What I did find was that the motor construction contains lots of plastic. It's made in China. Even the brush holder is plastic. Now, this is unusual to me, as brushes get very hot. However, I did not find any issues of melted or softening plastic when running. I used a laser-guided thermometer and measured about 170 degrees F on the metal portion of the brush holder. Nothing unusual. Some parts reached above 200 degrees F. Again, nothing unusual. The only unusual issue is that many of the parts are mated with plastic parts. That's where I believe the problem lies. When the motor is new, the brushes don't make full contact. Therefore, full power draw is not achieve until these brushes wear down a bit. After this point, the brushes reach maximum power delivery and reach maximum temperatures. This is why I believe the vacuum didn't exibit any smell until a few months later, at least, for us. In conclusion, I didn't find anything wrong, except that the motor is cheaply constructed. It isn't going bad and well likely last quite a while, IMHO.
MAJ
Posted on Jul 18, 2010
  • digtal_dremr Jul 18, 2010
    Additionally, I'll mention that I measured the ampere draw of the motor when running and it was under 9 amps most of the time, well within specs. The specifications refer to it as a 10 amp motor.
    This indicates that the motor was not dragging, pulling hard, and didn't have a shorted field or armature winding. Everything checked out okay - except for the plastic brush holders. LOL!
    MAJ
Burning smell
For an upright or canister with a power head
a burning smell is usually an indication that the belt is slipping. It may just be worn out or the brush and or bearings may be bound up with hair. Remove the brush cover, some are on top other on the bottom, and look for anything wrapped around the brush. Also look at the belt where it goes around the drive spindle, if you see small black specks the belt needs to be replaced. Check the brush fro free movement, if it dosen't spin easly the bearings may need cleaning.
Dec 28, 2014 | Vacuums
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
May 14, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
300 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
