Question about Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier
Marshall Lead 100 Mosfet head, no sound.
I have a marshall lead 100 mosfet from the 80's, it turns on but it doesnt put out sound through the cab, tried a different head through my cab so i know its the head thats causing the problem. please help.
    Scholar:
  • 73 Answers
Are you popping fuses??? check the effects, preamp, and power amp jacks to make sure they (even if not in use) are Normally Closed. Sometimes they loose their contact to ground on the Tip of the jack, which opens the circuit and interrupts the normal function. then check the input jack for good contact to the pcb and solder joints, as well as all pots (especially the volume). if all this checks out, and it still is having issues, i would then move on to the grounding resistors (solder welds can heat up and break as these resistors get hot) and resolder them to the board. still no output, then diodes / rectifier / filter caps.
Posted on May 04, 2010
Testimonial: "thank you!"
For me when I couldn't get a sound a put a a regular cable or 1/4 Mono to 1/8 Adapter in the back where it says "Return" but not all the way about half way through. Make sure your cables are plugged in and are no high volumes while you do this because you want to be strumming as you pull in and out of the Return jack.
In case it isn't the Return Jack try it on the Output or Send. One of these might be oxididate like my Return was.
Posted on Sep 10, 2010
There is no sound coming out of my Marshall 100 watt tube amp head?
make sure the standby switch is operating correctly.Sounds like the power tube.
Dec 18, 2013 | Marshall Amplification Marshall JCM800...
Marshall mg hdfx100 power switch fell off, is there a way to turn it on without the switch
power switches are pretty easy to replace, i have the mgdfx50 and its only 4 spade connectors, 2 blue and two brown, doesnt have to be a marshall, just a 4 pole switch from an electronics store
May 24, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
The fuses on my marshall amp kept blowing so i took out the output assembly and it worked, but there is no sound. the output chip was burned. Where can i get a new Output Module Assembly For Marshall...
If the output module has a TDA7293 chip/stick on it, replace it. Use thermal compound like they did and observe any insulating washers used. Clean board and check for shorts after replacing.
Get them at about $6:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=497-2170-5-ND
and
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=497-8865-5-ND
Depending on how the leads are bent... first one leads go down (V suffix), second they are bent horizontally(HS suffix).
Apr 04, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
How do I replace a fuse on a Marshall DFX 100, where is it located?
The fuse would be internal. The fuse blew for a reason, and unless you had an accident with the amp such as shorting a speaker lead, there is likely internal damage requiring servicing. Replacing the fuse without curing the original reason it blew will likely cause damage to further components.
Take the unit in for repair.
Sep 06, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
No head!
They were designed to be used with the Marshall MG100HDFX heads.
Jun 30, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
4 x12 slant cab grill is ripped its a '' MARSHALL''
From behind the amp there shouls only be a couple os screws that hold that fron panel on, once removed you can take it off to work on it, you can get the same material from a good music store or even some type of fabric store or craft store.
Mar 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier Logo
787 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
Vito Vacirca Jr.
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
