Wireless routers i need a wireless router and need to know which are compatible with my isp . my isp is orange using a speedtouch modem
    Genius:
  • 3,587 Answers
Most routers are compatible with many of the ISP's, due to conventions for use..you may want to go on google, and do a comparison..
I have some links to the big three, here, if you'd like to evaluate them from a technical standpoint.
Posted on Mar 25, 2008
SOURCE:
My router is connected to my modem and instead of a green right its an orange light it was working yesterday..i tried unplugging it and then using the click to fix button but it remains orange and tells me...
ix-Belkin router blinking orange An idea of Belkin router is blinking orange is simple but there can be many more reason behind that light code.
  • it just can be ISP issue (may be internet service provider is down )
  • you might want to restart the modem then router and wait for like 1 min this Belkin router blinking orange to green.
Just follow these steps and let's see if they work for you. restart the modem (DSL modem or ISP device) and restart the router.
If this did not fix the Belkin router we might need to perform a reset on Belkin wireless router. please visit here for more:
Belkin router blinking orange FIX belkin router amber light Issue
Nov 30, 2010 | Belkin (F5D7231UK4) Wireless Router
The wireless light is orange and blinking on a Belkin F6D4230-4 router: the wireless is not working
1 It just can be ISP issue (maybe internet service provider is down )
2 you might want to restart the modem then router and wait for like 1 min this Belkin router blinking orange to green.
For more details kindly visit
Oct 05, 2010 | Belkin Computers & Internet
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
Wireless router does not connect to the internet
While you have the router connected to your modem, try unplugging the modem and plugging it back in. This will force the modem to redetect network connections.
Apr 15, 2008 | D-Link Air DWL-122 802.11b Wireless...
Buffalo airstatio whr-hp-g54 router unable to connect to Orange speedtouch
I think the speedtouch modem do you have is a usb modem connection. The best solution is to call your ISP provider and request that you need to replace the usb speedtouch modem to LAN or RG45 connection. But the only problem you encounter if the internet you applied is personal only sometime they cannot provide the LAN connection to personal connection (like globe ISP).
Apr 08, 2008 | Computers & Internet
Belkin (F5D7633-4) Wireless Router and SpeedTouch 360
I have solved this issues. I simply had to change the VPI/VCI values which i have obtained from my ISP. These value differ from one ISP to another.
Thanks for all the people tried to help me!
Mar 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
29 people viewed this question
Ekse
Alun Cox
