Model----LT42322 PART NUMBER-fA2B-42406 fACTORY ID 07CDT-1 the power green Light do come on. but have blank sceen the screen stays black. when I turn on the set the light flickers a sort of yellow and then goes green. It's as if the TV is sleeping.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 01, 2010
Left sse05 in rain works but no screen
If you left it in the rain and now it does not light up, sounds like it is gonna cost you a new phone...moisture has more than likely got into the LED screen and is now bad...
Apr 01, 2014 | Lands Phones
Digital lifestyles model fa2b 32570
Could be a couple of things.
The good news is that the LCD panel is working, albeit briefly.
It definitely sounds like it's repairable, though.
Dec 03, 2013 | Televison & Video
My toshiba 32inch tv wont turn on
A lot here would depend on the model number as there are a lot of different ones with different issues.
Got a model number?
Mar 28, 2012 | Televison & Video
42' fa2b-42406-mdlt42322, no sound or picture, tv is only 2 years old bought 3.2008 from HSC, paid 1,200.00
THIS IS NOT A BIG ISSUE. THE PROBLEM WITH THESE IS CHEAP CAPACITORS GOING BAD. THE ONLY PROBLEM IS THE POWER IS ONLY GETTING TO THE POWER SUPPLY AND NOT FURTHER DOWN TO YOUR MAIN BOARD TO START YOUR TV. YOU CAN EITHER REPLACE THE POWER SUPPLY OR THE DAMAGED CAPACITORS. IN SOME CASES THE CAPACITORS BURN MORE PARTS SO IT IS ALWAYS BETTER TO GET ANOTHER POWER SUPPLY. THE BEST PLACE TO GET ONE IS WWW.TVPARTSANDMANUALS.COM PARTS WITH INSTALLATION INSTRUCTIONS AND CAPACITORS HAVE A HIGHER VOLTAGE RESISTANCE.
Jan 12, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
The stand by light led in the front is working but no sound or picture i have a ditital lifestyles hdtv model #LT42322 part number FA2B-42322 what can be causing this problem i already went through the...
Standby is usually red, are u saying when you press power it turns green but no picture still, or it never turns green? If never turn green then just replace power supply
Dec 05, 2010 | Televison & Video
I have a Digital Lifstyles 42
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
GOOD LUCK....
May 21, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Acer5630 unable to boot
remove your battery and on your system other wise reinstall the os
Mar 06, 2008 | Acer Aspire 3003LCi Notebook
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
