Question about Kettler Exercise & Fitness
Hello ! I am from 2 weeks a new kettler marathon tx 1 tredmill. Few days ago when I want to modify the rising angle , this one is out of order. So after it I saw that on the display is not shown the angle only 2 lines in the midle.I tried to push the button up but nothing was happend.I tried to use after it the program P4 and P5 also P8. Is not possible , when i push the button for change the program it appeaps P1-P2-P3-P6-P7 and again P1...... So I don't know What is the problem? I am very angry because in this situation I can't use the treadmill because when it happend the angle was 0. I want to mention that when I bought them 2 weeks ago , it was function corectly.thank you and I wait your answer.
    Problem Solver:
  • 23 Answers
DEAR
I THINK YOUR HAND BAR KEY INCLINE STUCK YOU SEE IT AND FREE THE KEYS STUCK .IF NOT YOU MUST GUESS ELECTROSTATIC ELECTRCITY WHEN YOU RUN ON AND TOUCH HAND BAR YOU GUESS A FEW ARC THIS IS BECAUSE OF YOUR BELT IS DAMAGE AND THE ELECTRICITY DAMAGE YOUR MONITOR AND YOU MUST REPAIR IT .
you can countinue contact us with smart phone on wattsapp or telegram by :
+989195116738
Posted on Apr 10, 2017
4 Suggested Answers
  • 19 Answers
SOURCE: problem when connecting lcd tv to pc
Update the video drivers on the PC. This is sometimes typical if you are running the Windows Default driver for a video card, or if the video card vendor has made a mistake. Usually there should be a new release, if the latter was true.
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
  • 14 Answers
SOURCE: The console display on my Horizon Fitness T63
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Posted on Oct 25, 2010
I cant get the water temp below 125 and I need to for our day care. I have the lower thermostat set to 110 and it still is 125 to 130 degrees. Is there something else I need to do. There is a upper...
You have marathon water heater?
Thermostat is probably bad. Has gone out of calibration.
Replace both upper and lower thermostats for $25 from local hardware store, takes about 20 minutes, turn off power, take photo of wires before starting. These thermostats can be adjusted all the way down to 90 degrees, and then dial up a bit to reach 110.
Copy following link for instructions how to replace thermostat yourself.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, then replace both elements.
Elements are special order made specifically for marathon.
Requires 1-7/8" socket to remove elements.
Upper 3800 watt, order part SP610130
Lower 3800 watt, order part SP210197
http://hometips.me/Mar/Rheem-Marathon-parts-2.pdf
http://waterheatertimer.org/How-to-replace-water-heater-element.html
More information about Marathon:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Gene
h
Aug 26, 2013 | Rheem MR105245 Marathon Electric Water...
Problem with Kettler Marathon ST, error 01 and not starting
adjust the speed sensor, see the diagram attached, clean, and tight the wires connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.l
After you did, RUN the software calibration for diagnose, troubleshooting,and fix it.
sincerely. GOD bless you
May 05, 2012 | Kettler Exercise & Fitness
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com or www.kettler.co.uk
Jul 17, 2010 | Kettler TX1 Treadmill with FREE INSIDE...
Treadmill won't start
If you have a multi meter I would first check the AC outlet follow the path (power cord, on/off switch, fuse holder, motor control board) to see if their is any power interruption . Also I have to ask is the safety lanyard attached to the upper console. Hope this give you some direction.
May 15, 2010 | Kettler Exercise & Fitness
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
142 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
