LAN connection won't work, but wireless does
My LAN connection stopped working suddenly and will not reestablish. It is connected directly to my modem properly, with all the components working properly as well, and yet there is limited-to-no connectivity. I have checked the ethernet cords, no issue there. I have contacted my ISP provider, who reset my modem and believe it is working fine, as well as toshiba tech support, reinstalling Intel Pro 100 LAN drivers, but nothing has worked. I believe the issue involves being unable to reset my IP address. My wireless adapter works fine as well. Does anyone have any ideas? Toshiba A105-S4211 Model# PSAA8U-0FJ02J
  • 5 more comments
  • dawipo May 01, 2010
    Thanks for your response. I'm not very familiar with manual operations so any directions on how to perform the IP address setup would be greatly appreciated.
  • dawipo May 14, 2010
    Hi. Sorry it took so long to answer back I just got my hands on another computer. I was able to successfully establish a local area connection beginning with 67.xxx.xxx.xxx, however I cannot access the internet still. Is this what you meant by connectivity? Is there another step to take from here? Thanks for your help.
  • dawipo May 15, 2010
    I am not currently using a router, I am connecting directly to the modem. I have been able to connect wirelessly to an unsecure wireless connection with the IP address 192.168.1.105. The 67.xxx.xxx.xxx IP address was on a Mac that was able to connect via the modem to the internet, however I have not had the same luck with my PC. According to my ISP, and the fact that the Mac received internet, tells me the modem works fine.
    you are correct in what you said. I have a toshiba laptop. Do you have recommendations as to what i should purchase/where i should go to replace the ethernet port?
    Toshiba Satellite A105-S4211 Model# PSAA8U-0FJ02J
    Thanks again.
  • dawipo May 21, 2010
    So I bought one of the ethernet adapters you recommended, however it did not solve my problem. My modem and computer establish a connection using the adapter with the IP address 192.168.100.10, with data being sent and received, however no internet connection is available. Unlike my actual computer ethernet port, which when i try to connect says there is limited or no connectivity, there is no such message for the adapter. Does this mean it's not my ethernet port that is the problem then?
  • dawipo May 23, 2010
    Still no luck. As soon as I connect the cable the icon looks like it is going to connect, then disappears. I disabled all the other network adapters besides the new one, and nothing.
  • 583 Answers
It sounds like the LAN card may be going bad. You can see if manually setting the IP address in the settings of the LAN card will work. If that works, then the card's routine for negotiating IP address assignment is corrupted. You maybe able to get some more useful life out of it by doing this until you can replace the LAN card itself. If you need more instructions on how to set the IP address manually, reply back and I'll try to step you through it.
Posted on May 01, 2010
  • 4 more comments
  • Mark Tidwell
    Mark Tidwell May 01, 2010
    OK, you'll need to find the address series that your modem issues to computers attached to it. You'll also need the DNS server addresses (this can be found from another computer connected to the network or from the ISP). To find from another computer, you'll go into Network connections in the control panel, right click on the connection that is connected to the internet and click on status. Click on the Support tab and click on Details. Here you'll see the IP address assigned to the working computer (probably 192.xxx.xxx.xxx), the subnet mask, the default gateway, and the DNS server amongst other items. Make a note of each of the addresses of the above items.
    Now, on the computer that is giving you problems, go into Network Connections, right click on the LAN connection that has limited connectivity and click on Properties. Scroll down to the Internet Protocol (TCP/IP) item, click on it to highlight (don't remove the check mark), and click Properties. Click the radio button by Use the following IP address:
    Under IP address: you'll need to enter the same series of numbers with the exception of the last set (after the last decimal point) as was on the working computer. Make the last set of numbers between 1 and 255. Preferably above 200 so that you don't accidentally conflict with another address on the network.
    The subnet Mask will be the exact same set of numbers as you found on the operating computer.
    The same for the default gateway and Preferred DNS server. If you had a second DNS server number on the working computer, enter it in the Alternate DNS server box.
    Click OK. Click OK and if the LAN card is working, you'll have connectivity. If this doesn't work, you'll need to use either your wireless or get a new LAN card.
  • Mark Tidwell
    Mark Tidwell May 14, 2010
    The DHP server function of the router has quit working because it is not assigning IP addresses. Addresses that begin with 67.xxx.xxx.xxx are self assigned by Windows. In this case, the router itself is not working properly. You can try to reset the router by pressing the reset button for 15 seconds or so, this will cause it to do a factory restore reset. If this does not give you connectivity, then the router/modem is suspect. Cable modems are configured by the ISP, so you don't have any options there.
    You mentioned that the wireless works fine though, what IP address do you get with the wireless? You can try plugging in the numbers as described in my previous post from the number sequences that you find associated with the wireless card.
  • Mark Tidwell
    Mark Tidwell May 15, 2010
    OK. I want to be sure I understand. You were able to connect to a wireless network that is not associated with your network which means that your wireless is working. This means that your ethernet port on the computer is no longer working and needs to be replaced. Is this a laptop or desktop/tower computer? If a laptop, you'll have to get a USB or PCMCIA ethernet card. If a desktop/tower, you'll need to purchase an ethernet card that is compatible with the bus inside your computer (PCI, PCIe, etc.)
  • Mark Tidwell
    Please provide the model number of the Toshiba laptop and I'll look it up for you and give you a few options.
  • Mark Tidwell
    Mark Tidwell May 16, 2010
    The following link provides a number of compatible cards.
    http://www.tigerdirect.com/applications/...
  • Mark Tidwell
    Mark Tidwell May 21, 2010
    Make sure the old adapter is disabled (check the Device manager under Manage Computer when you right click on My Computer). When you attempt to connect to the internet, the browser may still be trying to connect through the old port.
What would cause my wireless router to stop working?
recheck your connection from your router to your modem. Make sure your wireless button is turned on the computer. If all else fails reinstall your router with a data cable attached to reestablish the wireless connectivity.
Aug 11, 2014 | NetGear WNR2000 Wireless Router
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Communication trouble
What kind of router do you have? Are you using wired or wireless ethernet to connect through said router?
Mar 21, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Lost connection over wired LAN - wireless OK
A common fix is to re-set the modem. Just unplug the power to the modem for 30 seconds, then re-connect it. You could also bypass the router momentarily to see if the modem is working. Just connect one of the computers directly to the modem to verify connectivity. Your control panel should also have a utility to renew the IP address.
Sep 13, 2007 | SMC Barricade g SMCWBR14-G2 Wireless...
Computers & Internet Logo
819 people viewed this question
David Payne
David Payne
