Question about Maytag Atlantis MAV6000 Top Load Washer
When our washer is spinnig it is makking a loud noise
    Problem Solver:
  • 7 Answers
Your load is off balance, the basket assembly has come loose or the bearing needs to be replaced
Posted on May 01, 2010
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
Started to make a loud noise whilst spinnig every other process is ok any thoughts would be apreciated thanks.
Sounds like jet? rear tub bearing;; this is the time to replace before more damage is caused. Good luck
Mar 24, 2011 | Washing Machines
Why is my washing machine making a loud banging noise when spinnig?
wip the top off and have a look at the big stabilizer springs that hold the drum up if one is missing or broken off replace it,,,,if these springs brake or fall off the washer dose a grate dance around the floor done it?
Nov 24, 2010 | Indesit W 123 Front Load Washer
Pump is makking Load Vibration niose .Installed Foam around pump it sceem tom help
When the drain pump is making that much noise or vibrating excessively their is something internally wrong in the pump.something hung up inside or a bad or loose impeller, either way i don't think it will be long before you will have to replace
Sep 22, 2010 | Kenmore HE2 Plus Front Load Washer
Very loud noise when spinning out of 1st cycle and now water leaking out of bottom
the main bearings have worn out and should be replaced soon as possible if left the drum will colapse as the bearing shatters could cause other damage to machine parts it will normally fail when the machine is under most load whilst high speed spinnig
Jan 16, 2010 | Washing Machines
Loud
This could be a bearing getting noisy in the transmission. But we have to try and pinpoint where the noise is coming from. And did it start suddenly? Or gradually get louder over a few weeks?
Jan 05, 2010 | Kenmore Washing Machines
When the car is started and while driving it is produceing a very loud whining noise. It gets louder when i accelerate. The noise is being compaired to a siren on a fire truck. What could be wromg??
It sounds as though your alternator bearing is about to fail. Take a long screwdriver and carefully place it on the center of the body of the alternator, away from the spinnig fan. Place your ear on the screwdriver handle and listen for any bearing growling sounds. This is most likely your problem.
Oct 08, 2009 | 2004 Dodge Stratus
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
Spinnig slow sqecking noise
This is joyce
sounds like the belt needs to be tighter. sounds like its slipping on pully. that may be why its not spinning correctly.
thanks
joyce
Feb 06, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
