Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Samsung HLN5065W...replaced color wheel and lamp. TV turns on and lamp illuminates for approx. 10 seconds, then goes out. All three LED lights on the front of the TV flash when this happens. Any idea?
  • Samsung Master
  • 5,138 Answers
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
Posted on May 01, 2010
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Feb 25, 2011 | Samsung HLN5065W 50" Rear Projection...
My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
LEDs Blink but TV will still not come on
This appears to be a logic problem, (address missing) in which case you would need to get a schmatic diagram in order to fault find. It could also be a psu problem, excess current, (trip) short, or excess voltage which is preventing the set from turning on, monitored by the logic hence, giving you blinking LED's.
Aug 31, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR4667W has no picture or sound when turned-on.
you have tried lamp,color wheel .............it sounds like the DM module not powering up.........it is very expensive repair ......
Feb 04, 2009 | Samsung HLN5065W 50" Rear Projection...
Ballast or Lamp?
Its not the lamp or the ballast board. In either case, you would lose picture (going blank or black) and sound would soon follow then the LEDs in front would blink if at all.
Odds are its either the DMD board or the digital board.
michtech
Feb 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP
once again either the color wheel or lamp ballast needs replaced OR....the DMD board needs cleaned which you can do yourself for free if you are mechanically inclined(see my other posts for instructions on how to do this)
Dec 21, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
1,020 people viewed this question
Jerry Greenberg
Jerry Greenberg
