Question about Ducane 30400040 Stainless Steel Grill
Using ceramic briquettes with lp gas grill
Will using ceramic briquettes with lp gas grill improve the performance of the grill?
  • 8,197 Answers
Many people enjoy using Lp/gas grills for their ease of use and efficiency. Frustrations caused by flare ups and hot spots encourage the use of a wide variety of briquettes and other products. Ceramic briquettes are most commonly used because they provide an even heating surface and last for several uses.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. "SOOC" is Copyrighted by Flickr user: Robert S. Donovan (Robert S. Donovan) under the Creative Commons Attribution license. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.co.uk/images/a05/8n/jr/should-use-briquettes-gas-grill-1.1-800X800.jpg'); }); Types
  2. Gas grills most often use ceramic briquettes, lava rocks or, more recently, ceramic tiles in order to distribute heat. Ceramic briquettes come in the traditional shape, lava rocks are similar to those used in landscaping, and tiles only differ from briquettes by shape. Traditional charcoal briquettes can be used, though they maintain several disadvantages. Use
  3. Place briquettes, tiles, or lava rocks in a solid layer on a screen between the heating element and the grill surface, making sure to leave space for air to circulate. Light the grill and check to make sure that all areas of the heating element are covered, filling any empty spaces. Advantages
  4. Ceramic briquettes, tiles and lava rocks all serve the same purpose. The advantage comes from their ability to reduce flare-ups and hot spots. They can also be used several times, minimizing set-up and making cleaning easier. Traditional charcoal briquettes are cheap and easy to find. They also provide the smoky flavor associated with traditional charcoal barbecuing. Disadvantages
  5. Ceramic briquettes, tiles, and lava rocks are not as easy to find as traditional charcoal briquettes and are more expensive. Traditional charcoal briquettes do not repel run-off from food, but rather retain it, causing hot spots and flare ups. Charcoal briquettes also need to be replaced after each use and are harder to clean up. Warnings
  6. Any additional product placed inside a lp/gas grill should not come in contact with the heating element. Doing so can cause increased stress to the grill, as well as clog vital gas ports. Always maintain a clean grill. A buildup of old briquettes can cause inadequate performance.
Posted on May 01, 2010
How much ceramic briquets should be used with this grill
You might try googling "flavorizer bars" and see if you can find the right length to fit your grill. Weber makes these for their gas grills, and they are much better than using lava rocks, ceramic briquettes or tiles. If the bars are too long, you can cut them down to size with a hacksaw. Well worth the extra work as they are far superior to the others.
Apr 09, 2015 | Grilling
Char glo indoor gas grill
leave at least 1/4 inch between briquettes. sometimes clients will pile-up briquettes hoping to make the grill hotter or more efficient but the briquettes can become an impediment to heat circulation which will cause heat to spread low. this usually damages the module and control valves. A single layer with small space between each briq is sufficient.
Oct 29, 2013 | Thermador Grilling
When I try to start the propane grill (Ducane)by pushing the knob and turn to hi, it creates a spark and from the "pilot" there is a big flame straight up, I hear and can smell the gas , but that...
It sounds like something got disconnected between your gas line and your venturi (which deliver gas to your burners. Take out the grills and whatever holds your rocks or ceramic briquettes and look at the connection where the flame is coming from. It may be obvious what has come apart, and the fix may be as simple as pushing it back together.
Jul 15, 2017 | Ducane 30400042 (LP)
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Need Briquettes only!
You can purchase them from either your local BBQ's Galore store or online @ http://store.bbqgalore.com/store/category/8/60/Burner-Systems/
Happy Grilling!!
Apr 03, 2011 | Barbeques Galore Turbo STS 4-Burner with...
I want to buy just the charcoal for my Patio caddy. Nyoungwirth@san.rr.com
You can purchase the briquettes at any store that sells grills and accessories.
Aug 14, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Need to clean the briquets. What do I use?
usually people just burn them off but you can use a paint scraper and scrape them off there is alot of flavor in having dirty briquettes
Jul 18, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Bynasty BBQ - Need briquette trays; left, right(
They have them at DynastyStoves.com/parts.php
30 inch models need one notched and one regular tray. 42 inch grills need two regular and one notched. they have the briquettes too.
Jun 30, 2009 | Dynasty DBQ-30 (LP) Grill
Do I need to use Briquettes with this grill?
i had the same question about no briquettes and still haven't gotten an answer!! The food doesn't really taste like its grilled outside on a grill! Can you please let us know!!
Apr 19, 2008 | Uniflame FG2204C Grill
Ducane 30400040 Stainless Steel Grill Logo
1,481 people viewed this question
Top Ducane Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
