Question about Roper RAS8445KQ Top Load Washer
My agitator dosent spin anymore the bottom part still does
Might it be agitator ears
    President:
  • 1,218 Answers
Good day,
If what your referring to is the agitator isn't performing properly, then if it's a split agitator, it is usually the "dogs" that have failed.
Here is an excellent tutorial on replacing them.
You will need ordinary hand tools and at least one long ratchet extension.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on May 01, 2010
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
Agitator top portion not working
You need dog ears for your agitator. They cost about 50 cents and are in stock at most appliance parts stores. Tor replace them remove the top cover from the agitator. Uncer the cover there till be a bolt to take the agitator off. They are 4 pieces of plastic that resemble dog ears and lock your agitator in one direction while allowing it to spin in the other.
Oct 25, 2009 | Washing Machines
Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Sep 22, 2009 | Whirlpool Washing Machines
WILL NOT AGITATE
Hello, it could be 2 things.
1) You could have worn out dog agitation ears
2) Could need a new transmission
Dog agitation ears would be my first choice and it's pretty easy to fix. Parts will cost you around $10.
Good luck :)
Aug 06, 2009 | Kenmore 27721
Top-loading, direct drive Kenmore model won't do spin cycle
In other words it pumps out but when it goes into spin nothing happens. The first thing to check is to remove the tranny(get the agitator out) take the 3 bolts loose and slide out the tranny(no need to get the tub out) Take a look see at the plastic brake release collar mounted on the bottom of the basket drive. The ear will break off and thus no spin.3ef16e8.jpg If that looks ok let me know...
Jan 07, 2009 | Kenmore 22422 Top Load Washer
WEAK AGIATOR
Does the agitator shaft turn real easy or does it stop or keep from turning 360. It should have limits and not free wheel or turn around and around. Does it spin correctly? Most generally the parts you are looking for would be accessed from beneath the unit. Not sure about what dog ears are but there are plastic pieces that make the unit shift from agitate to spin on some models. If it has slight resistance to turning the agitator shaft but will turn 360 the gear in the transmission is probably stripped out. Do a little looking from the bottom and turn the shaft while looking at the bottom to see if you can tell what is out. You might find broken parts on the floor under the machine...
Feb 10, 2008 | Washing Machines
Remove Agitator Whirlpool style Top Loader
i think that the agatator may have a screw in the side of it nearer the bottom stem if so slacken off and pull ajatator off main shaft
if no screw just pull agatator off
sometimes takes a bit to get off
do not turn machine upside down
Feb 01, 2008 | Washing Machines
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Agitator won't spin back and forth like its stripped
I think what you have going here is some worn agitating ears. In the appliance world we call them dog ears. You have to remove the fabric desp, it should just pop off. Under there will be a cap that you can grab with a needle nose pliers and pull the cap off. Now you will be looking at the bolt that holds the agitator to the shaft. Remove this bolt and you can get to the dog ears and plastic bearing. There is a kit for this and the part number is 3951682. This is not a hard fix...just take your time and observe. Catriver...post back.
Jul 29, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper RAS8445KQ Top Load Washer Logo
32 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
