Question about Dishwashers
Water in the bottom of the tube the drain hose is fin no kinkys or clog is there a internal filter in side the washer
  • 247 Answers
It's normal for there to be about a hoseful of water left in the sump at the bottom of the machine after the cycle is over - it happens because the drain pump only works on water, so is never able to blow the last slug of water through the hose. Once the pump stops, this water runs back into the machine.
The sump is designed to be big enough to hold this amount of water without the level rising high enough to come back into the main cabinet, but in some machines you can see to the bottom if you look in the right place.
The installation instructions for the dishwasher will have had lots to say about size and position of the standpipe the drain hose goes into. Failure to follow these can increase the amount of water that runs back at the end of a cycle, so that might be worth a quick look if you think the quantities are excessive.
A.
Posted on May 01, 2010
Not draining. checked filter. Drain motor runs and fins are spinning
The drain pump can be running, but if the drain filter or hose is clogged, the washer won't drain. Check these first.
Jan 03, 2015 | Washing Machines
Our LG Tromm WM1814CW frontload washer is not draining in the spin cycle, but its only sometimes. We have tried cleaning the Filter and its clear, we looked in where the filter is to see if its clogged,...
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
Dec 14, 2017 | LG WM1814CW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
MY AMANA WASHER WILL NOT DRAIN
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Dec 03, 2009 | Amana Washing Machines
Altus washing machine wont drain
2. Water Pump
3. Drain Filter
Nov 26, 2009 | Tecnik TKL9260 Front Load Washer
Washer stops midway incycle and code says OE
2. Water Pump
3. Drain Filter
Nov 20, 2009 | LG WM-2277HW Front Load Washer
I have a maytage epic front loader, its flashing F21-book says drain problem, How can I fix it?
2. Water Pump
3. Drain Filter
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore washer is spinning but not draining. What should I do ?
2. Water Pump
3. Drain Filter
Oct 27, 2009 | Kenmore 44102 Front Load Washer
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
Defrost drain
That pipe is the drain tube. Must be clogged.
May 10, 2009 | Refrigerators
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
