Question about Bebecar Raider AT Stroller
Lower basket is badley damaged
My lower basket is badley torn. do you know were i can buy a new one
    Scholar:
  • 91 Answers
Replacement baskets can be purchased from your local retailer or from Bebecar U.K. directly. 01692 408807. service@bebecar.co.uk
Posted on Jan 25, 2010
Torque steering or pulling under acceleration
Some cars just do that. Since we don't know what kind of car nor year, we really aren't going to be much help without a little more knowledge.
Oct 20, 2014 | Cars & Trucks
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
Kitchenaid dishwasher model kudm24se the upper and lower baskets have rusty areas. Would like to replace with new baskets or a method of correcting or fixing the rust spots
That is not that hard to replace and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jun 02, 2011 | Dishwashers
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Nov 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Rollers fell off my lower basket of my dishwasher. Need to get a new basket for bottom.
That is not that hard to fix and you can easily buy the parts yourself online...
heatman101
Sep 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Car is cutting out badley on incline
You might consider a new fuel filter, and also check the fuel pressue
May 11, 2009 | 2001 Lincoln LS
COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Right lower ball joint. Torn loose from lower control arm. Ran into a sinkhole in road,wrecker driver lives next door, and saved me a few bucks on towing thank goodness. Arm is OEM. Wrecker driver...
If you torn the ball joint out, you very well could have more damage.
If you plan on doing the work yourself, I would put the car up on stands, and take the front wheel off, and do a through examination of the whole assembly.
Once you have a complete assesement of all of the damage you can go to your local parts house and get the parts.
If you have to replace the lower arm, you will need probably need some specialized tools (like a spring compressor).
After you're done changing parts, you will need to get a front end alignment.
Jul 27, 2008 | Mercury Grand Marquis Cars & Trucks
Bebecar Raider AT Stroller Logo
126 people viewed this question
Top Bebecar Baby Gear Experts
john milligan
Tom Chichester
ray gallant
Are you a Bebecar Baby Gear Expert? Answer questions, earn points and help others
