Question about Dishwashers
Not enough water comes into the dish washer. - Dishwashers
  • peteyf97 May 01, 2010
    I will try your solution and see what happens. I'll let you know if it worked.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 01, 2010
  • Rylee Smith
    Rylee Smith May 01, 2010
    OK, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Will not clean dishes
Sometimes because of water pressure the inlet valve doesn't allow enough water into the machine to satisfy the float switch so you don't have enough water to completely clean the dishes.Manufacturers install whats called a flow washer to control the flow of water into the machine in case of too much water pressure. What you can do is remove the flow washer from the valve itself to allow enough water to enter the machine. The other problem could be that the water is not hot enough. Some water heaters are set to 120 deg. to save on utility bills. To clean effectively the dishwasher water temp needs to be at least 160 deg. which is the temp restaurants use to clean and sterilize their dishes. Check to see if your dishwasher has a water heat switch on the control panel that will increase the water temp to 160 deg. If not just turn up your water heater temp. To check water flow just open the door when it is finished with the first fill right before it starts washing and check to see if the float switch is satisfied. You can check it by just pushing down on it and listening for a click. Either one of these should solve your dirty dish problem. Good luck
Nov 08, 2012 | Whirlpool Dishwashers
White film is all over my inside of the dish washer & dishes
This sounds like excess soap or not enough water. You may also have really hard water.
Turn on machine wait until it starts running see how much water is inside. there should be a 1/2 to 1" +/- in the bottom but not enough that the wash arm would be touching and not enough that the door would be leaking when you open it. This could also be a circulation problem set wash arms a certain way and observe that they have moved when you open after running for a minute or 2.
Please let me know if I can do anything else to help.
Apr 13, 2010 | GE Dishwashers
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
No water spraying in washer, and no error code
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Jun 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
No water is coming out of the spout in the dishwasher
I am experiencing the same problem on my kenmore dishwasher (model: 665.1702). there appears to not be enough water spraying out of the washers as the soap is still in the dispenser at the end of the wash and the dishes are dirty. I've tried removing the bottom washer but can't figure out how to remove it. Did either of you find a resolution?
Dec 02, 2007 | Kenmore 24 in. 17669 Free-standing...
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
Owen Barnes
