Question about Whirlpool ET8CHEXSQ Dryer
When dryer is started the timer can be heard and if the door switch is activated, the heating element will heat, but the drive motor does nothing. belt is ok
  • Whirlpool Master
  • 1,252 Answers
Try holding the door button, have someone push the start button and you spin the tub at the same time. If it starts, it is most likely the start capacitor on the motor. If it does not start, look at door button, start switch/button, and lastly, the timer.
Posted on May 01, 2010
Mde3500 Electric Dryer will not heat
it sounds like the door switch itself is good but has a poor connection after the switch. That would explain why the momentary light flashes. The heating element will not start unless the door switch is sending a constant closed signal. Check your wiring & control board.
May 02, 2014 | Maytag Dryers
My GEQ9800 dryer will not start. Start relay switch is good, timer is good, thermal fuse is good, door switch is good, input power is good. Nothing happens when you hit the start switch.
Is it plugged in. Seriously,
what about the heating element, have you tested it?
here is a link to replace it if it's bad
http://www.ehow.com/how_2240320_change-heating-element-dryer.html
Sep 30, 2011 | Whirlpool Dryers
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Ge dryer #DBXR463ED2WW does not start and power is going to dryer
You said, GE dryer #DBXR463ED2WW does not start and power is going to dryer
Here are the 5 most common reasons for your Electric dryer not to start.
Door Switch
The door switch must be operative before the dryer will start. Ensure the door switch strike is properly actuating the switch and if so, check the door switch for continuity with an ohmmeter for proper operation.
Faulty Drive Motor
If the motor will not start, it is possible it is defective. The wiring of the motor is different for each brand and you will need to refer to the wiring diagram of your dryer for the specific terminal locations. You will need to use a volt/ohm meter to check for resistance between the run winding and common (may be referred to a neutral). If there is no resistance, the motor is open and will need to be replaced.
The motor bearings can also go bad. A dryer with a motor in this condition can sometimes be started by hand and it will run. However when the motor gets hot the bearings begin to seize and the motor will stop. In this condition you must also replace the motor.
Electric Dryers:
On Electric dryers you will need to check the heat element for resistance. With the power disconnected, remove the two wires connecting to the heat element and check the resistance of the heat element by using a volt/ohm meter. The resistance should be between 5 and 50 ohms of resistance. If there is no reading the element is defective and will need to be replaced.
Heating Source
If the element is not receiving power it is likely that one of the thermostats is defective.
Thermal Fuse
The thermal fuse is in series with one leg of power to the motor. If the fuse is open (no continuity) the motor will not run.
The thermal fuse is located in different locations according to the model and brand of dryer.
Solution:
Check the thermal fuse for continuity with a volt/ohm meter. If it is open, it will need to be replaced.
Timer
The timer is the source for power to the motor and if the timer contacts are defective, there will be no power getting to the motor. Since the wiring is different between brands and models, you will need to refer to your wiring diagram for terminal locations. Once you have located the correct terminal for the motor operation, you will need to turn on the dryer and check for 110v from the timer terminal for motor operation and the chassis ground. If you have the voltage, the timer is most likely okay and the problem is elsewhere. If there is no voltage, the timer is defective and must be replaced.
Thank you for using just answers.
Please remember to leave a solved rating befroe you sign out!
Huuum
Jan 23, 2009 | Dryers
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Keeps heating on cooldown
needs new timer switch
the timer swithc contains 2 switches one for the motor and one for the heating element, the element switch has fused closed. not reliably repairable,
even if open the timer, break apart the contacts, file them smooth, reassemble, will still lock up again
replacement is less than a new dryer
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer won't run
This sounds like something may be mis-wired...or there may be a defective switch contact in the timer or one of the other controls. If the heater element comes on with the blower motor not running, it should quickly overheat and trip one of the thermal shutoff switches.
Feb 01, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool ET8CHEXSQ Dryer Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
