Question about Garden
John Deere 3000psi pressure washer stalling
The pressure washer runs fine for 1.5 - 2 hours then stalls and shuts down. I let the system cool down a bit and it will run another 10-15 minutes before it stalls again.
  • 29 Answers
First off, that pressure washer wasn't designed to run for that length of time. The duty cycle is about a half hour on and 15 minutes off. If you have a rural water system make sure you have adequate water volume and that yo have a screen in line and clean it also. If you get sand into the pump you can sore the walls.
Posted on Apr 26, 2014
    Problem Solver:
  • 5 Answers
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
Posted on Sep 26, 2010
Have a john deere skidsteer 317 starts and stalls, restarts and stalls, replaced filters , same results starts , stalls
does that have a electronic Fuel Solenoid on the bottom of the carburetor? if so start there. If it's going bad that's the result your getting now. Don't leave fuel in the tank all season long. fuel stabilizer is coca cola. If no shut off valve thern drain almost al the fuel out and add WD-40 to remaining fuel until engine runs dry. this will keep your fuel system clean all year round.
Aug 29, 2017 | John Deere Garden
Kawasaki 17 hp stalls when hot
you need valve job done and new valves put in and i said new valves do not use old valves again 150.00 per cylinder
Sep 07, 2014 | John Deere Garden
Why does a john deere 345 stop running after an hour like it doesn't get fuel and then run again after it cools off?
Could be that the coil is getting hot and stops working. Verify that the impedance is within speck. If not, replace it.
Sep 04, 2014 | John Deere 325 345 Tractor Service Pricing...
John Deere X300 stalls after running for 1 hour
Diesel filter clogging up, may have water in it
May 15, 2012 | John Deere Garden
84 john deere 410b stalls out
could be something floating around but did you fuel it one day and not the other try and run it with the gas cap off there is a vent on the cap that gets plugged
May 13, 2012 | John Deere Garden
I have a John Deere 170 ( Kawasaki Engine), after mowing about an hour and get in some taller grass, it starts to sputter and then stalls. It will start up but still sputtering and stalls again (...
it sounds like the coil is breaking down at high temperatures. when a coil gets hot it expands. when it cools off it work right. i would change the coil and try it. i think that will solve your problem.
Sep 26, 2017 | kawasaki Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Garden Logo
474 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
