Question about Car Audio & Video
Kenwood subwoofer do not know if i have the right box + wiring for a 1500w kenwood duel coil sobwoofer in my hatchback need to know what will work.
    Sergeant:
  • 300 Answers
See your other post.
Posted on Mar 27, 2008
I got these subs given to me brand new from my dad and was not sure on how to wire the duel voice coils. Could you please tell me the different ways to wire the coils for the different ohms. Thanks, Gerald
Ok..If each coil is say 4 ohms and you wire them in parallel you will obtain 2 ohms...in series you will obtain 8 ohms...remember..series resistors add together and parallel resistors(of the same value) divide...so if you were to wire all 4 voice coils in parallel, then you would obtain 1 ohm...or, if you were to series all 4 voice coils then you would obtain 16 ohms...a lot of amps are not stable down to two ohms..the way we did it old school was to parallel each speakers voice coils to obtain 2 ohms..and then we would series the 2 speakers in the box to obtain the 4 ohm load needed by the amp
Jan 07, 2011 | Jensen KS-210 Car Subwoofer
How to wire duel voice coil and amp
You would wire it like two speakers positve to positve and minus to minus that will work best without getting in to deep that will keep your restince equil on both sides like right and left.
Aug 23, 2010 | Car Audio & Video
I need to know how to wire duel voice coil 12
one way if you want to run it off 1 channel is to wire one voice coil to the other making sure +goes to +, and -goes to -,then wire your amp to one of the coils, but i found just running each coil to a seperate channel on the same amp was the best way,
May 28, 2010 | Insignia Car Audio & Video
I have two 12 in. subs single voice coil and need to know if could run a 1 omh stablb amp and if yes and how
Yes, you sure could. Each sub is a 4 ohm load. When you put them in a box connect a wire from the + terminal on each speaker, and connect that to the + terminal on the box. Do the same from each - terminal, connecting to the - terminal on the box.
This is called "wiring in parallel" and it will split the load in half, so you present a 2 ohm load to the amp. Since your amp is rated down to 1 ohm, it will work just great.
Feb 07, 2010 | Kenwood 12" 4-Ohm Single-Voice-Coil...
AMP
That amplifier is only stable to 2 ohms.
You will only be able to use one Dual 4 ohm Subwoofer wired in parallel (all + to + on amp.... all - to - on amp.
This will yield a 2 ohm mono load.
It is impossible to wire (2) dual 4 ohm voicecoils to achieve a 2 ohm mono load.
If you're set on using both subwoofers - they will not be getting as much power from your amplifier with a 4 ohm load - but it is your only option.
SEE THIS LINK for the wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 02, 2009 | Kenwood KAC-8104D Car Audio Amplifier
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Box type, dimensions And wireing for a 2 12''4Ohm duel voice coil
http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html this website will help you out with wiring but as far as box info what kind of box do you have and if its going on protect mode you need to turn your system down bkz your running to much juice. either that or you have a short somewhere
Nov 16, 2008 | Directed 3124 Car Subwoofer
1500w duel coil subwoofer
Depends on the type of music you listen to and the type of sound you want out of the box. If you're looking for "as loud as possible", you'll probably want a ported box, as this will make the output of the sub peak at a specific frequency and drop off at others. If you wanted more of an even response across many frequencies, a sealed box is probably best. Kenwood has recommended sizes in the owner's manual.
Mar 25, 2008 | Kenwood KFC-W3514DVC Car Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
