Question about Oregon Scientific RM318PA Clock Radio
Unable to change from Pacific Time to Central Time Zone
I am unable to change from Pacific Time to Central Time Zone with my Oregon Atomic Clock. What is the problem. It stays in Pacific Time Zone and I live in Tulsa, Oklahoma which is Central Time Zone during the Spring and Winter.
Can U help me.
Thanks
  • 10 Answers
SOURCE: Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Posted on Mar 08, 2009
SOURCE: Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Posted on Mar 09, 2009
SOURCE: can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
Posted on May 21, 2009
SOURCE: I have a barolo atomic clock, batteries went
Make sure the day is displayed instead of seconds, then homd down the + button for 5 seconds. Every 5 seconds should advance it on zone. Had same problem and just got done resetting mine this way.
Posted on Jul 17, 2009
BillB-SA
  • 2761 Answers
SOURCE: Oregon Scientific Model 323a--Atomic clock...the
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Posted on Aug 01, 2010
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How do I reset the time zone? I have tried to follow the directions with no luck.
Is the picture the type of clock your referring to? If so you cant set the time zone on that type of clock. You can change the time though.
Nov 05, 2014 | La Crosse Radio Controlled Atomic Clock
How do I change the time zone?
Radio controlled atomic clock self sets, and self adjusts automatically. This clock is very easy to use!,Daylights Saving Time on/off option; 4 Time Zones - Pacific, Mountain, Central, or Eastern,Folds into smaller size for easy storage and travel; travel pouch included,Automatically sets day, date and time; 2 separate alarms - great for weekends,Sturdy, contemporary construction. Stand folds for easy storage. 2x AAA batteries included; as shipped to U.S. Government and institutions
Oct 13, 2014 | Marathon Genuine Atomic Travel Alarm Clock...
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
Atomic clock is 2 hoursfast
You need to reset it to YOUR time zone. The default on this model is Pacific Coast time so you must be in the Central Time Zone (2 hours ahead of Central). Instruction manual should show you how to reset.
Feb 09, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Mt atomic clock is always 2 hours slow no matter
How to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
Sep 26, 2009 | Acu-Rite Adagio Clock Radio
Can't figure out how to set the time zone
May 18, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
display mode.
display map
Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Sharp Atomic Clock spc 373 won't display correct time/zone
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
Sep 23, 2008 | Zapf Chou Chou 716212
Oregon Scientific RM318PA Clock Radio Logo
57 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
