Question about Dishwashers
I need athe tech sheet for a Fridgaire dishwasher Model # FDB2310LCC2 serial TH54472931
  • rwh34222 May 02, 2010
    Thanks--that is just what I needed! Also thanks for the fast reply.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please click on the link to download the Tech. Sheet for your Frigidaire Dishwasher FDB2310LCC2. Please do accept the solution if the issue is resolved else revert for further assistance.
Thanks
Rylee
Posted on May 01, 2010
Clean light keeps flashing and dishwasher won't start.
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back with your MODEL NUMBER and let me know
Apr 26, 2011 | Whirlpool Dishwashers
Clean light flashes continually and washer will not start
On Whirlpool manufactured dishwashers, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
Apr 25, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean light flashes,will not start
On Whirlpool manufactured dishwashers (such as Kenmore), the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
If you still need assistance, please post back with your MODEL NUMBER and let me know.
Apr 20, 2011 | Kenmore 24 in. 17463 Built-in Dishwasher
The clean led light on the dishwasher keeps flashing 7 times and dishwasher wont start.
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it's often attributed to the heating cycle or thermostat failure. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
Please post back with your MODEL NUMBER if you still need assistance.
Apr 18, 2011 | Dishwashers
I have a model FDB2310LCC2 dishwasher and it won't turn on. The column cycle lights washing cleaning drying and sanitizing are all blinking simultaneously along with the "high temp wash" light. I...
This may be a problem with the door interlock switches. You will need to shut off power to the dishwasher, unscrew the control panel and remove the wires to the door switch ( make note of where the wires go on the switches) and check the switches with an ohm meter ( do this with the door closed, the switches should show good continuity). repost if any questions.
Jul 11, 2010 | Dishwashers
Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
May 07, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Dishwasher wont drain
Look for food in sump and drain hose, if clear may need drain pump
Mar 03, 2010 | Dishwashers
Clean button light blinks 7 times, pauses and blinks 7 times. This repeats over and over. Dishwasher will not work. Model is DU1055XTPS4
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The light blinking 7 times can commonly attributed to a thermostat problem. However, before assuming you have a component failure, read through the following information.
The following link explains how you may be able to clear the blinking clean light problem:
I hope this helps you solve your problem.
Jan 06, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
The clean light is blinking, and the cycle won't
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
Jan 06, 2010 | Dishwashers
I have a kitchen aid dishwasher model # KUDM01TJWHO The clean light has a 7 code. Your link to diagnostic mode/reset didn't work for this model. The tech sheet isn't behind the kick plate nor door panel....
you need to see if your getting power from the control all the way to the heating element something in the heating system is not working. some times the element burnes out and takes out the other stuff with it, so check for continuity at the element and thermostats befor replacing the control if all are bad it cost as mutch as a new washer or allmost
Dec 08, 2009 | KitchenAid Dishwashers
Dishwashers Logo
Top Dishwashers Experts
