Hp sb 21 it will not show any video i gto it 2ed hand and when i turn it on the unit powers and i hear a buzzing noise and u hear the moter spin 3 times then the lamp light comes on i was wondering is it just the lamp or more
  • mailfast9371 May 01, 2010
    but is that the only thing that needs to be replaced
  • 12,061 Answers
H10032.www1.hp.com/ctg/Manual/bpia6001.pdf
http://www.dell.com/projectors
http://www.avispl.com/service-support/projector-troubleshooting.asp
Ok, above, a troubleshooting guide, above that is the Dell, support, above that is your user manual. Below is a service manual, not for your exact model, but it will help.
www.everestdisplay.com.tw/db/.../P65%20service%20manual-20070912.pdf
Things to look at when you have no picture from projector
1. Laptop or computer is not connected correctly. Check your cables and note where it is plugged into on the back of the projector. Make sure the projector is set to display from the right port.
To check this there should be a button on the projector or the remote for the projector that allows you to cycle thru all the input connections
2. If using a laptop make sure that the laptop is sending video out to the external video port. This is normally done by pressing the FN key and one of the F# keys. Example on a Dell laptop press FN + F8 sends video to the external video port
Please note that there are normally 3 modes to the FN + F# keys on a laptop when pressed. You may have to press the combination more than once to get output on the laptop and projector.
MODE 1 Laptop Display only
MODE 2 Projector Display only
MODE 3 Projector and Laptop display
Please note that the FN + F# combination key will be different depending on manufacturer
3. Check for problem lights on the projector. Some projectors have “Overheat” and “Lamp check” warnings indicators.
4. Projector lamp has failed try reseating the lamp. .
Projector is overheating (Over heat indicator on) or the cooling fan is running at high speed all the time
1. Clean the cooling fan intake and filter. Replace the filter if needed, do not run the projector without the filter.
2. Check for intake vent obstructions, if projector is ceiling mounted.
The picture from the projector is tinted (Red, Green, Blue, Pink or some other color)
1. Check the cable connection from the computer to the projector
2. Someone has adjusted the colors wrong. You will need to reset the projector back to factory settings. This can be done thru the buttons on top of the projector or with the remote.
3. If the above does not fix this then you will need to send the projector in for service. The Video display board is faulty.
Picture is too wide for the projector screen
1. Display resolution is set to high for the projector to handle, change the display resolution to a lower setting.
2. Press the “Sync” button on the projector and let the projector resync itself to the incoming video.
3. Reset the projector back to default settings
4. If the above does not fix the issue then chances are the Projector will not support the video out of the computer that it is connected to.
Projector is not responding to the remote
1. Replace the battery in the remote.
2. Make sure that that the IR sensor is not obstructed.
Posted on May 02, 2010
    President:
  • 1,768 Answers
1.We will need the model number here to further assist.
2.this is more than one issue here but there is not enough information to go on.
3. I will need to know how the screen looks etc.
4. I suspect a high voltage section may be the or the B+ side of the main board is possibly failing or failed
A tech will be the only one that to determine the malfunction and the components that needs replacement.
Posted on May 01, 2010
  • 10,594 Answers
If lamp light turns On that means lamp is not working and possible reason would be broken lamp or got reached to end of its working hours life.
Replace lamp in projector to get it fixed.
Lamp replacement procedure is written in user manual, click HP Support to download manual copy, if required. Please reset lamp hours after lamp replacement as its mentioned in user manual.
Hope this info will help you.
Thanks.
  • Shahid Electronics
    Shahid Electronics May 01, 2010
    Yes, symptom shows projector needs lamp replacement.
I have a buzzing noise on all extensions on a per cab, I have just replaced the per cab but the buzzing/humming noise is still present, any ideas?
Noise troubleshooting (part 1) ' - Gilmourish
www.gilmourish.com/?p=1211
Mar 21, 2010 - You've probably experienced hearing this loud buzzing from your guitar and if you ... strips) but in any case, make sure that all extension cables have ground! .... never used an instrument cable between the head and speaker cab... ... Each unit has separate lines for each pedal for a more consistent signal.
G1962 Noise: The Invisible Hazard - MU Extension
extension.missouri.edu > ... > Safety and health
University of MissouriFarm workers experience one of the highest rates of hearing loss among alloccupations. This is ... Frequency is measured in cycles per second, also called hertz (Hz). ... to noise: temporary threshold shift (TTS) and ringing in the ears (tinnitus). ... Just as tractors are different, so are cabs in their ability to reduce noise levels.
Questions, Troubleshooting Help & Support Page 8 - Fixya
www.fixya.com/troubleshoot/page-8
Get free troubleshooting help, expert advice, repair guides & DIY tips for all your ... I have a buzzing noise on all extensions on a per cab, I have just replaced the ...
The Hospital - Volume 21 - Page 110 - Google Books Result
Jan 20, 2016 | Cars & Trucks
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Sony dvd player makes noise when turn it off
It is in the standby portion of the power supply which runs 7/24 if the unit is plugged into power.
Dec 06, 2012 | Sony Televison & Video
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
After oven turned on for normal baking it starts to hum rather than typical noise from exhaust fan.
If you're not hearing the fan turn at its normal speed, it is possible that your fan motor has become stalled. AC motors will often hum or buzz when they can no longer turn but still have power applied to them. This could be due to bad bearings, or a blockage of some sort. It's probably not easy to get to, but if you can hand check the fan it should spin quite freely. Be sure to unplug the unit before messing with the insides, or shut of its circuit breaker if it's a built-in unit.
Dec 24, 2010 | Dacor ECS130 Epicure Electric Single Oven
My Whisperflo was making a buzzing noise while pumping. I turned it off to clean the strainers and now when I turn it on it makes a loud buzzing noise and the motor does not spin. The impeller moves...
it's a bad start/run capacitor. It's under the hump on top of the motor. DO NOT touch the terminals with your bare hands in case the capacitor is charged. You can replace it with an exact match.
Sep 06, 2010 | Pentair 1.0 Hp Whisperflo Pump
Will fill up with water but will not spin and just makes a buzzing noise?
there are two possible problems one the lid switch might be broken there is a small tab front right corner of lid that goes down into a hole to operate the switch which i beleive is still good because you can hear the moter hum there is a drive coupling between the moter and transmission if you lean the machine back you will find black rubber debries in the middle toward the front of machine before taking apart unplug from power the pump has two clips that hold it on top of moter there are two screws in two clips that hold the moter to a metal plate next to transmission the wiring harness plugs in to side of moter the drive coupling can be worked off gently with a wide screw driver from moter and transmission each plastic piece has three
pins that line up and fit into a hard black
rubber center the trick is lining it back up and clipping the metal supports back on moter i normally clip the top one back on first gravity assist with correct placement of moter to reinstal bottom clip reattach wiring harness two screws in moter clips reinstall pump will probably have to turn moter shaft to align with pump reinstall pump clips
Dec 07, 2009 | Roper RAS6233KQ Top Load Washer
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
SENDING UNIT ???????
most of fuel pumps were in tank, wire corrodes is harness under right front seat floor pan to tank
if fuel pump buzz is heard and car runs and when it doesnt run you cant hear the fuel pump try
turn ignition off wait 10 seconds
turn ignition to on position to (prime or hear pump buzz)
no buzz fuel pump not working check fuel pump relay(swap with another) and try again?
you could use test light to pump wiring and make sure your getting power to pump on this prime test no power relay or wiring problem.
power at pump, but no buzz fuel pump faulty
Jul 01, 2009 | 1997 Isuzu Rodeo
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
