Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a John Deere 420 garden tractor it wont shift from high to low range, also the throttle ramps high to low it sounds like the thing is gonna blow up,I have cleaned the carb what's next?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Check just above the idle fuel mixture screw on the front side of carb and see if the 1/4 inch welch plug blew out of carb.You should see a hole if its blown out of housing,if still there you would barely make out its location,these blow out for 2 reasons,using compressed air to clean carb and a back fire through maniforld.If still have problem I would suspect a split intake manifold near where it goes into block causing an air leak.Both of these are common problems.
Posted on May 05, 2010
  • Bill
    Bill May 05, 2010
    Forgot about the 2 speed.With engine off,you on the seat,with right hand pull back on lever towards the seat then over to high or low.Ours has a lock out that didnt start to work {pull back then over} until other parts started to wear out.
No spark while cranking,only when you turn the key off?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Dec 05, 2015 | John Deere Technical Service Repair Manual...
My John Deere 420 onan stops for no reason after running for ten minutes Restarts immediatly.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Jul 07, 2015 | John Deere Garden
My 755 is stuck in low gear
If the (High,Low) engagement handle is loose and can move (Low to High) and the tractor stays in low, look for external linkage for missing or loose parts. If the engagement handle is tight and will not come out of low position it sound like there is an internal problem. Look for any external obstructions on the linkage that would keep it from moving. If not the problem could be an internal problem. Possible internal problems could be shifting fork,shifting shaft, or shifting linkage.
Oct 28, 2014 | John Deere Garden
Where is the hydraulic oil resivore on a John Deere 420 garden tractor?
Its the transmission itsef, you fill it from under the hood between battery and steering console. Its a little black cap that lifts off tube.
Jun 20, 2011 | John Deere 420,1020,2010,2020,2510,2520...
How do I shift my John Deere 420 garden tractor from high to low speed? I can't budge the shifter. Is there a trick to it?
With engine not running,pull lever towards rear of machine then move from one side to the other.If this does not work your linkage is locked up externally.
Jun 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
179 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
