Question about George Foreman GRP99 Indoor Grill
Broken Part Where can I order a new part for my GRP99? I dropped it and the plastic piece that is right under the control panel broke in pieces. I can see that this piece is screwed on so it looks like I should just be able to take it off and put a new one on if I knew where to get one.
  • 4 Answers
I called Fox-International and ordered a new Grill Plate Handle for my GRP99.
$14.95 includes Shipping.
Dave in Ohio
Posted on Aug 13, 2008
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
I can not get my tailgate to unlatch and open. what do i need to do to get it to open?
i had the same problem with my 2002 1500, the problem lies with a clip or both clips being broke under the tail gate latch that you pull on to open it. you can check this by getting a flash light and look up under the latch as you have it pulled up, you will then see if you have a broken clip. chevy dealer has these. to replace the clips you have to remove the square plastic piece around your latch handle, this square piece has 4 plastic tabs 2 on the upper piece of the square in the corners and the low portion of the square has 2 in the corners also, get 2 putty knives and slide one under the bottom half of the square plastic piece 3 quarters of an inch from the corner, then slide another putty knife under the very corner, note cover this knife with tape as it will scratch your paint if not careful. you will hit a plastic tab shove in carefully to disengage the tab, do this on the other side,then you can remove bottom half of plastic trim, then proceed to do the same step on the top of the plastic trim, once this is done then take it off carefully these plastic tabs are fragile! then proceed to look in the area to see which clip is to be replaced, use needle nose pliers to install new clip, just put clip on shaft that has dropped down, this would be the one that has the broke clip. then after installing new clip try your tailgate if it opens, if it does all is well. install your square plastic piece top first, then the bottom until it snaps into place.
Dec 11, 2010 | 2002 Chevrolet Silverado 1500
My 2000 mustang convertible lh interior door window switch insert panel has come off. End piece seems to be broken off. Top has plastic tab that snaps into door panel, but won't stay in. Is there a clip...
You need to order a new part if you're missing the parts that broke off. There's been some success using epoxy to repair but that's usually a short term fix.
The part is easy to find either at a salvage yard, eabay, or online places lie CJ Pony parts.
Sep 25, 2010 | 2000 Ford Mustang
I have a Royale Dometic refrigerator in my 1999 trailer. The plastic piece on the upper right of the main door broke. Its one of the pieces that holds the door open when it swings open. The whole door fell...
You are able to order a new door, without panels (reuse your old ones), from Dometic. You can also try seeing if a used parts outlets has them as well. One that I use frequently is Colaws RV Salvage.
Jul 14, 2010 | Refrigerators
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
The latch that opens the Trunk (Hatchback - as it is a minivan) is broken. I cannot open the back...
If you still have the broken piece, you can try to use that to try to open the back. Otherwise, you have to open it from the inside.
I changes mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Now to see and pull on the cable, and replace the latch, you have to take off the inside liner/panel to get to the latch to replace it. This took about 2 careful hours to replace.
The trick is to get the two side pieces off.
These two plastic pieces are next to the window on the left and right sides. Each piece is about 3 inches wide and 18 inches long. Using a strong grip, or a pry bar or large screwdriver, take off both pieces. There are three clip areas that holds each piece in.
If you are using a tool, be careful to protect the area by wrapping a towel on the screwdriver/tool.
After that the bottom liner piece pulls away and you can see the latch.
There are two screws/bolts that holds the latch.
The two pieces snaps back in pretty easily.
You probably broke the plastic piece shaped like a J.
You can try to glue the pieces back, but note that the piece broke due to age. I changed the whole assembly - good for another 7 yrs. I could not find just the plastic piece.
Aug 29, 2009 | 1999 Toyota Sienna
My 1999 Toyota Sienna has a broken rear latch
I answered this for someone else -
I changed mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Apr 13, 2009 | 1999 Toyota Sienna
Hayabusa killswitch broken
You'll have to complete the circuit. Twist the two wires together should get you a band-aid to the dealer…
Nov 10, 2008 | 2003 Suzuki GSX 1300 RZ Hayabusa
Cosco Buckle Broken
Bought a new car seat
Sep 26, 2008 | Cosco 02-442
Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Sep 08, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
George Foreman GRP99 Indoor Grill Logo
137 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
