Question about Technics SL-1200MK2 Turntable
How old is my Technics SL 1210 Mk2
Hi I wonder if you could help, how old is my Technics SL 1210 Mk2, its serial number is MJ6306F131?
Thanks mike
  • 1 more comment
  • Anonymous Oct 10, 2008
    ag8315f100
  • richard vreede
    richard vreede Aug 22, 2014
    And don't forget that your unit propably is built from 4 turntables.....
  • Matt Clarke
    Matt Clarke Apr 07, 2019
    Anyone help work out the age of my 1210 ? GE1GX001015 & GE8EW17847 Thanks in advance
  • 515 Answers
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Posted on Apr 10, 2008
    Sergeant:
  • 432 Answers
So it\'s time for refurbushing the inside parts if it has never been done. replace the caps, replace the tonearmmwire and technics cable , buy a new platter shaft unit and clean the pcb\'s from beneath and after that just use a spran to protecht it, clean fader if it still helps. And the funpart is : you need to know this before you buy a unit. So many mk2 and most of them are way too expensive, looking at how many work it needs, i only buy mk5\'s
Posted on Sep 19, 2014
SOURCE:
Technics 1210 mk2 humming
Hi, it needs to be earthed to your mixer or amp. Cheers john
Feb 03, 2013 | Technics SL-1200 Turntable
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
1210 mk2 only playing through left speaker checked everything and needs new rca phono lead how easy is it to change thanks
If you have done some soldiering and have a steady hand, it's not difficult. If you are not sure, you could destroy that little circuit board that the lead runs to, and technics had discontinued production of that part. I'd say get it done by a pro with experience.
These guys are top notch:
http://www.repairnyc.com/
Hope this helps.
Jan 13, 2008 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
9,327 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
