Question about Garden
I have a troy bilt that will not start. I purchased it last year, so it is pretty new. I finally got it to start after quite awhile of working on it.I put new gas in it and it worked for a short time. it shut itself off. I tipped it over to work on the lead head and would not start up again.
  • kckruse May 01, 2010
    I took out the spark plug; it was grayish black and dry. It was not wet. I cleaned it off with carb cleaner. I also sprayed carb cleaner in the combustion chamber and put it back together. and it still would do nothing.
  • 10,319 Answers
Remove and replace the spark plug since you had tip it over. It will be oil soaked and burnt now if started. Also add some carburetor cleaner additive to clean the varnish out of the fuel supply.
Posted on May 01, 2010
  • frank thomas wilson
    frank thomas wilson May 01, 2010
    Check the spark plug wire with an ohm meter. It should register 20,000 ohms or more if good
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have a Troy bilt snow thrower 2 stage-storm 2410. Bought it new last year, used it twice. It won"t start even after adding new gas and changing the spark plug. It doesn"t start, engine...
You need to remove the carburetor float bowl and clean it. The needle and seat also need to be cleaned. The best thing is to totaly remove the carb. and soak it in a commercial/professional strength cleaner.
Your problem is fuel related, but just to make sure, remove the spark plug and spray some carburetor cleaner in the hole, replace the plug and give it a pull. If it fires up then quits..... The fuel system is to blame.
Hope this helps, Matt
Dec 10, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Troy-bilt self-propelled w/briggs and stratton 6.75hp after starting runs for 3 or 4 mins. dies out and in 3 mins later will start and do the same thing any suggestions?....thanka abb
Hello. Your carburator is partially clogged up. That said, if you havn't installed a new fuel filter and new air filter this year do so. Also put in a new plug if u havn't lately. Finally get a bottle of a fuel additive called seafoam and pour it into the fuel following the directions on the bottle. J.
Aug 16, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Tines will not turn when engeged. made a grinding
It sounds like a problem with the drive pulley on the engine to me. Maybe the key is striped.
May 27, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Engine dies out
Could be any of several problems. Since you indicate you just bought it, I'd suggest you return it. Troy-Bilt is pretty good at making customers happy and should repair or replace it right away.
Apr 09, 2010 | Troy-Bilt Pony Garden Tiller
Can't get primer to move gas thru carb on a tb70ss. what do i do/
just take carb apart pretty simple to take apart. it has probley been awhile since it was last run right? the carb is gummed up need to take apart and use carb cleaner real good
Jul 08, 2009 | Troy Bilt Tb70ss Gas Trimmer
Trimmer will not start.
Yes. Your carbeurator is gummed up. Get some new gasoiline and add some carbeurator cleaner to it, usually one ounce per gallon. Dump the fuel u have in there and put in the new fuel.
Also, get some spray carb. cleaner, remove the air filter and put a couple of squirts into the air intake chamber. Then start it.
Finally if it still won't start, use a squirt of starter fluid to get things going and get the carbeurator cleaning into the system.
May 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
