Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
My 670 honda has no spark on both sides - V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
How to set the timing on a honda gx 670 motor with no timing marks
Hi, if it's a newer style bike, it could be like a newer car. Not possible to change the timing.
Dec 21, 2016 | V-Twin Horizontal OHV Engine with Electric...
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Rebuilding a honda 670 v twin no timing mark on crank gear only cam!how can I time without that crank mark?
I am assuming your working a GX670 twin cylinder small engine.
There should be small dimple on the crankshaft gear. It is 180 degree from the keyway. Note the gear maybe on backwards.
here picture of the Honda setup from one their service bulletins.
Nov 04, 2014 | Cars & Trucks
Gx 670 twin getting spark &gas wont start
Check the flywheel keyway, they will shear and cause the problem you are encountering.
Nov 22, 2013 | V-Twin Horizontal OHV Engine with Electric...
Honda gx 670 chokes and sputters in thick grass or when goose throttle
It sounds to me like the carberator is a little dirty, drain the bowl and clean the main jet. Also while you are there check all the jets and make sure they are open not clogged.
Sep 09, 2013 | V-Twin Horizontal OHV Engine with Electric...
Dell precision 670 diagnostic lights y g y
http://www.dell.com/support/Manuals/us/en/19/Product/precision-470
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
http://www.ebay.com/itm/DELL-H2703-PRECISION-470-670-VRM-VOLTAGE-REGULATOR-MODULE-TH-0H2703-WS470-WS670-/380369885440
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
Headlight assembly repair 1984 honda elite
Where to find a head light motor for a 1984 Honda elite cb125. Part number 33210-KJ9-670. I have tried to fix my old one no luck. Brushes look ok and motor will turn if I take it out of its holder.
Jul 22, 2012 | 2006 Honda Elite 80
CS-670 . Cleaned fuel tank , lines , carb. New
Check for blue, snappy spark at the plug (gapped at 0.020"). If weak or nothing, remove the flywheel cover to expose the ignition module. Check the module gap with a thin business card--turn the flywheel magnets under the module poles, insert the card into the gap, loosen the module screws, and allow the module to contact the magnets, then tighten the screws. Turn the flywheel somewhat to remove the card. Recheck for spark--if ok, try for engine start. If still no spark, remove the ignition switch wire from the module and retry for spark. If still nothing, replace the module. Install per the above instructions. Hope this helps!
Jul 06, 2010 | Echo Garden
Replace convertible top - honda S2000
I imagine there should be a Honda Dealership somewhere nearby...
I listed 5 dealerships in Central Western Massachusetts.
Bedard Bros. Honda 391 S State Rd
Cheshire, MA 01225
(413)743-0014
Lia Honda 293 King St
Northampton, MA 01060
(413)586-8626
Lorenz Honda 409 Federal St
Greenfield, MA 01301
(413)774-3200
Balise Honda 1371 Riverdale St
W Springfield, MA 01089
(413)788-4097
Curry Honda 767 Memorial Dr
Chicopee, MA 01020
(888)670-6440
I hope this helps you out.
Mar 20, 2009 | 2002 Honda S2000
1995 Honda Civic Spark Plug Wiring
The spark plugs are numbered starting on the drivers side (1) to the passenger side (4), the distributor rotates clockwise, and the firing order is 1 - 3 - 4 - 2
Oct 18, 2008 | 1995 Honda Civic
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
120 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
