Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Wont dry dishes and walls of washer wet after cycle. Heating element ohms out at 9.0. No recent changes to detergent or cleaning practices. Any suggestions. Thanks for the help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Check the water temperature inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 01, 2010
My LG doesn't seem to be cleaning very well or drying. The dishes are very wet when it cycles off. And the bottom of the washer is pretty gunkey. I have used the washer detergents for removing build ups...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 15, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
The dispenser door opens but the detergent is not released into the dishwasher. After the cleaning cycles are done, I open the dish washer door and the detergent is still in the tray. What could be the...
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
We have a FGHD2433KB1 model dishwasher. Among other problems that I have seen here (detergent door not opening, dishes not clean at the end) our biggest problem is that the dishes are never dry at the...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 20, 2010 | Frigidaire FDB956RB Built-in Dishwasher
My KitchenAid dishwasher is not getting my dishes clean.
Sounds as though the heating/drying element or the controller has gone kaput... You will probably need it serviced.
Jan 31, 2010 | Dishwashers
Maytag 300 dishwasher won't dry goes through the whole cycle but dishes still wet when done
The most common reason for dishes not drying is a failed heating element. Normally the other symptom of a failed heating element is glassware coming out with a film on them and not really clean.
Please report back what you find, OK?
Aug 05, 2009 | Dishwashers
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Drying cycle
To start ensure that heating element and fan are working.
The element can be tested reading ohms with a multimeter.
The fan can be tested evengizing it.
If the fan and element are Ok, then test and eventually replace dryness sensor and timer board.
Dryness sensor can be tested using a multimeter.
Jun 21, 2009 | Miele G848I Dishwasher
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
Wet dishes
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher stopped drying dishes at end of cycle
check the heating elemt circut and make sure that heated dry has been selected it the machine allows to need the model of the machine for more help
May 05, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
23 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
