Question about Vizio L30WGU 30 in. HD-Ready LCD Television
What am supposed to do if my t dosen't have HDMI
What am supposed to do if my t dosent have HDMI input source?
i have a Sonya Plasma television (model PDP -42H2AMC) and i have a Ps3 i bought Hdmi cables and everything i need but found out hen i got back home my Tv dosent have one. Is there something i can get so i can play my game Hd the way i meant it to be?
    Sergeant:
  • 418 Answers
Either HDMI to DVI adapter cable if TV has DVI in. Or component video cable (Green,Blue,Red jacks, plus White,Red for audio. Both will do HD.
Posted on May 02, 2010
Testimonial: "Oh ok thank you very much ....now to find the cords ...lol"
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
Panasonic Plasma TV TC-P65S2 HDMI INPUT not working
Have you selected HDMI through the source menu? It is a little odd for none of them to work!
Jun 16, 2015 | Panasonic Televison & Video
My Panasonic Viera HDTV Plasma model # tc-p46st3 . T.V. Turns on but NO Picture and the Red power light stays on. Can anyone help with this problem? And is this a job I can do on my own?
do you have the correct "input" or "source" selected? assuming you are using HDMI connectors, when you hit the source button on your remote, make sure you have the correct HDMI selected. Usually, an HDMI corresponds to a "cable box"; or a Blu-Ray player; etc..
Dec 19, 2014 | Televison & Video
Iplugge in my PS3 using an HDMI cable and i get no feedback
ps3's are a pain in the _ss..
you need to connect it through your standard cables as well.. use the component cables that came with the ps3 and connect it to your tv's coloured inputs..
change the tv to that source and then go to the video settings on the ps3, and then choose the hdmi option..
now.. once the option is chosen, you have about 30 secs to change the source on your tv to the hdmi source to see the picture while the timer counts down (making sure both the hdmi and the component cables are connected to the tv at the same time)..
now that you are on your hdmi source on the tv, choose accept (X) on the ps3 menu and you should have your hdmi setup
if you run out of time, no problem, just go back to your component source input and repeat the process faster
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Jun 06, 2009 | Toshiba 26HF85 26 in. Television
I have only the cable and hdmi hook into my panasonic 42 plasma and i dont get anything that is hdmi is there other cables i need?
Using your input key on the remote should switch you to the other modes. If you cannot access any HDMI or other input labels, go to your menu, and into the Input Labeling menu (under settings) and make sure you have all the inputs you require enabled. Its possible you (or an out of the box error) put these other inputs offline, which is why you aren't able to access your media from HDMI. If all inputs are enabled, and labeled, double check all the HDMI inputs on the unit. Plug what you are using with HDMI into each port, having the power on and sending information to the television. In some rare cases, I've seen that it doesn't allow access to the HDMI without it providing some source information.
Hope that helps.
Apr 09, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Dec 04, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
125 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
