Question about Vizio L32 32 in. LCD HDTV
Vizio L32 television Reset V-chip with no password. Someone in my household was playing with the remote and set the parental v-chip. There is NO password because they were just pressing buttons No children in this household so don't need the v-chip.
  • 10,594 Answers
Reset v-chip code is 8205 for your Vizio L32 tv.
Hope this info will help you.
Thanks.
Posted on May 01, 2010
Someone messed with parental control yesturday now when yo turn on tv it stays black screen and shuts off
This is not a user fault. Can be the main board or power supply fault. You will have to try to verify. May pay to replace the set of out of warranty.
Apr 30, 2015 | Vizio L32 32 in. LCD HDTV
How do i get my tv working again
Janet, it is possible your television was on placed on timer, remove the timer then move on.
Aug 21, 2014 | Vizio L32 32 in. LCD HDTV
How do i get the parental lock off my set
Hello
To reset the parentian lock password in Vizio TVs do the following
* Get into it MENU and come towards Parential Controls window.
* When the MENU button is pressed, the On Screen Display (OSD) appears on the Image Settings page.
* Press the [Channel Down] button to change to the Parental Controls page.
* Press the OK button and the first of the 4 Password boxes will be highlighted.
* Press the [CHANNEL UP-> CHANNEL DOWN-> VOLUME UP-> VOLUME DOWN] buttons in this exact sequence. Press the OK button
* The password has now been reset to "0000" and the following message will appear.
You can reset it after. The above said buttons will be on the center of the remote control within a circle. OK.
Jul 11, 2011 | Vizio 42 in. LCD TV
Tv turns on by itself
Unusual. most likely reason is a failure of the standby management chip which is a component of the sets power supply board, they usually blow up rather than initiate uncalled starts though. This needs examining by someone who has experience with flat screens. If you were to look at vizio l32 psu on google, you'd see why.
Jan 13, 2011 | Vizio L32 32 in. LCD HDTV
Someone changed the passcode on my Vizio 32L TV and I no longer know the code for it. How can I change it?
Hello there
To answer you question;
This has to do with the parental guidance/lock.
It is all very well explained in the user manual that you will find here:
http://www.retrevo.com/support/Vizio-L32-TVs-manual/id/512dj084/t/2/
Hope this help my friend and look for the pass code in the parental lock section.
Good luck
Sep 24, 2010 | Vizio L32 32 in. LCD HDTV
We just recently moved and we just got are cable hooked up and the tv now has a parental control on it How do I get it off?
You control access to the Parental Control features with a password. The default password is “0000”. You can
change the password to any four-digit number.
To change the password:
1. Press the MENU button to open the main On-Screen Display
(OSD) Menu.
2. Press the on the remote control three times until the
Parental Controls menu opens.
3. Press button on the remote control to highlight Parent
Lock Enable. The “Key-In Access Code” window opens.
4. Use the number pad to type the default password (0 0 0 0), then
press OK.
5. Press button on the remote control to highlight Access
Code Edit.
6. Press the on the remote control to enter into the submenu.
You will need to use the number pad to type the default pass
word first.
7. Use the number pad to type the new password.
8. Confirm the new password by retyping it.
9. Press the EXIT button on the remote control immediately to exit the OSD menu.
Dec 11, 2009 | Vizio L32 32 in. LCD HDTV
Password reset
V-chip code is 8205 for Vizio L32 tv.
Thanks.
Dec 10, 2009 | Vizio L32 32 in. LCD HDTV
Someone changed the parental code how do i reset it the channels are locked out and i don't have the code
The factory code is 0000 Try using that first if not try doing a factory default reset through your TV setup options . I believe your T.V. input cannot be setup to HDMI to access the parental control submenu. If you can't reset it give Vizio a call and they will help you figure it out. That's what they get paid for.
Oct 25, 2009 | Vizio L32 32 in. LCD HDTV
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Vizio L32 32 in. LCD HDTV Logo
306 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
