Question about Dell Dimension 8300 PC Desktop
When i try to boot it up it gives me 5 2 2 1 in beeps. whats it tellin me?
  • 2,841 Answers
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
My apple macbook won't start and continuously keeps on giving a beep sound.
the beep pre-boot is signaling a kernel panic. It could be bad ram or something else, it's hard to tell without hearing the beep (they signify different things)
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
taken from http://www.welovemacs.com/whdoallthbme.html
So depending on the beep, it means different things. However in any case I'd suggest taking it to an Apple Authorized Repair Facility. Unless you feel comfortable with assessing the proper solution on your own
Good Luck.
Feb 17, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
G31TM-P21 normally boots with series of beeps. Now will not boot properly from CD start sequence (for reinstalling op system) and gives a short beep about every 5 seconds. No information found on MSI...
According to the sequence of beeps your getting from your computer, ther is a possibility that there is a problem with the memory module or RAM on your computer. Try reseating the memory then try to boot up again.
Cheers!!
Sep 02, 2010 | MSI G31TMP21 (890552671946) Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
On boot up the emachine now beeps every 5 seconds
Reboot with "F8" held down.
you are only booting to bios and minimum disk software. This may give you an indication of your monitor or video driver status.
If you can borrow another monitor from someone, that would confirm your monitors status....
Oct 14, 2009 | E-Machines eMachines Desktop PC
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
HP dx5150 Microtower PC won't start up just beeps
That's what's called a POST beep code. The HP DX5150 beep code info can be found at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=447468&prodTypeId=12454&objectID=c00868914,
but for your benefit: 5 beeps means you have a memory problem. Take out the DIMMS (memory sticks) and reseat them. Try to boot. If you get the POST code again, you have bad memory (unlikely, but could also be a bad FSB on the motherboard). If you have more than one memory stick, remove one, try to boot, if you get the error, put it to the other memory slot, try to boot...then do the same procedure with the other stick. If you can get it to boot on one stick, you know the other is bad.
Mar 14, 2009 | Computers & Internet
Dell Dimemsion 8200 Won't Boot - Beeping Sequence 5-2-2-1
Often simply disconnecting the power cable, holding power button for 15 seconds, release power button, plug back in will work
Otherwise remove CMOS battery and perform above operation
Hope it works
Feb 03, 2009 | Dell Dimension 8200 PC Desktop
No boot but a 5-second beep
sounds like your memory is messed up, try some different memory in your PC.
Aug 28, 2008 | Intel D101GGC Motherboard
Dell Dimension 8300 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
