Question about Garden
Briggs and stratton lawnmower engin the exhaust gets red hot
  • 2,841 Answers
Sounds like it is running too rich on fuel. Try resetting the carb adjustment screws. Turn them in until it starts to stall and them turn the screw back out 1/4 turn. It may also be a partially clogged muffler or the screen on top of the engine may be clogged. In rare instances it may need the valves adjusted.
Posted on May 01, 2010
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
Sep 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
280H07-0166-E1 briggs engine blows smoke out exhaust
smell the oil if it smells like gas then the needle and seat in the carb is leaking if not remove the cylinder head and see if the gasket blew out and its sucking oil from the crankcase if not look at the bore for scores scratches and scraps
Aug 13, 2012 | Briggs & Stratton Briggs Stratton...
Cannot restart, without priming, my 8.75 hp Briggs and Stratton engine.
thats common for a old engine to have to choke it to restart it cold or hot
May 31, 2012 | Briggs & Stratton Briggs Stratton...
Illastrated picture of 6.75 briggs and statton lawnmower engine to identify parts
go online to briggs and find there parts manual for that engine and print it
Dec 07, 2011 | Briggs & Stratton Briggs Stratton...
I stored my Briggs and Stratton Murray 4.5 Lawnmower at an angle and oil came out the exhaust.
Just let the mower sit on the level for a while. Then be sure to check the oil level before starting the engine. It'll probably blow some oil smoke, but then it should clear up and be fine. You should only tip your mower in one direction, ever. That is down on the handlebars; up on the front. This way, the fluids have no where to run. Also be sure the gas tank is not full or fuel will run out the vent in the cap.
Oct 09, 2011 | Briggs & Stratton Briggs Stratton...
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
