Question about Smeg 23 in. SE64 Gas Cooktop
My smeg cooker is brand new! after cleaning it - one of the rings will not ignite properly, it clicks so gas is coming through but no flame! any sugestions?
  • 20 Answers
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
Posted on May 05, 2010
Why is the ignition not firing on my smeg gas cooker
It may be dirty. Try cleaning it and let it dry.
Aug 30, 2014 | Smeg Cooktops
The igniter spark for all gas rings remains on permanently without pressing down the gas flow knobs. I can see nothing prompted this - I just came into the kitchen one morning to hear the igniter clicking...
This could be a problem with your spark module. its an electronic box either behind or under the cooktop. it sends the spark to the spark tip, which then ignites he gas. So in my opinion i would say it is your spark module.
Feb 02, 2011 | Smeg 23 in. SER34AX1 Gas Cooktop
All 4 of the hobs started sparking/ clicking after cleaning the cooker top. Now they won't stop sparking/ clicking.
there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
Feb 26, 2010 | Smeg 23 in. SE64 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Cannot ignite central gas ring on smeg 5-ring kitchen hob
I had a similar problem on a different gas range but your problem seems the same as mine was.
I examined the underside of the burner and saw a little 'flash' left from the casting process and I filed it off. This made the problem worse; it wouldn't light at all anymore.
I tried the opposite, blocking off the burner channel from the gas feed pipe to the spark gap; problem solved. It hasn't had a hiccough since.
I can only imagine that the flow of gas toward the spark gap was so strong, the gas was blowing itself out.
Not knowing exactly how the underside of your burner looks or how the gas is partially diverted to the spark gap but I drilled a small hole in the casting, inserted a length of copper wire (the gauge used in house wiring), then 'tuned' the flow by clipping part of the wire off and trying it. It might have taken all of 15 minutes to correct the annoying problem.
Nov 24, 2008 | Smeg 23 in. SE64 Gas Cooktop
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg 23 in. SE64 Gas Cooktop Logo
572 people viewed this question
Top Smeg Cooktops Experts
freddyfox
Timllfixit
ray gallant
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
