Question about Uniden Cordless Phone
Dial tone can't get a dial tone...cordless panasonic phone is 2 year old. Battery charge bar is full. Phone is plugged in.
Throw it against the ******* wall..I hate these god damn phones
Posted on Apr 01, 2008
SOURCE:
Panasonic KX-TG2722 no dial tone
"No dial tone" certainly needs a bit more information. Technology requires doing the most simple aspects first then on to the complex. For starters, did you try a different phone line? Is the phone service turned on? Is the unit plugged into the wall and fully charged? More info required for your request.
Aug 27, 2014 | Uniden Cordless Phone
How do I get a dial tone?
Is the base station plugged into the phone jack on the wall?
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
No dial tone
Try disconnecting all units plugged into telephone service. ie. phones, computers, fax machine, sat. rec etc. Then take a known working wired phone to check for dial tone in each of the jacks. Plugging in each unit one at a time, you should be able to find your bad equipment. Disconnect bad equipment and reconnect remaining.
Apr 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
We have 4 cordless panasonic phones and none working only bleep
I switched the phone off at the socket and switched it back on, and it is working now.
Apr 09, 2009 | Panasonic Lands Phones
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Hi i have a panasonic xyg67160es telephone i can not make eney calls i have cheqed that the man line is ok with an old phone i have lost the instrushions
1. Make certain you are using the correct charging plug in adapter. This can cause serious troubles.
2. Replace the batteries and if no dial tone..........
There is no setup or program that will give the cordless set dial tone once removed from the base.
3. Make sure the cordless you have came with that base.
Let me know if this helps....
There are other things we can check with more info.
Feb 19, 2008 | Lands Phones
CORDLESS PHONE - NO DIAL TONE
Plug out the power from the main charger and then plug in again. It needs to reset after they have gone dead. Immediately you can lift one of them off the charger and you will hear your dial tone.
Apr 18, 2007 | Uniden DXAI5588-2 Cordless Phone
Uniden Cordless Phone Logo
87 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
