Depending on the model of bluetooth headset it is either 0000 or 1234. If those don't work, please put the make and model of headset in the reply to this.
The only thing I can find that has a model number of N95 is a Nokia phone. What is the manufacturer of the headset? The phone is asking for the PIN code that is programmed in the headset, so what I'm trying to do is locate the manual for your headset to see what the code is that the phone is looking for.
It is possible that the phone wants your personal PIN code as some bluetooth headsets uses the phone's security feature in which case you would enter the PIN code that you use to unlock the phone. Otherwise, other pin codes that are less common are 9999, 8888, 7777, etc. Without the manufacturer's name and model number, I can't help much more than that. Someone else maybe able to help you it none of those work.
You can't enter the pin code into the headset, it is preprogrammed and fixed. If you are successfully putting the headset into discover mode and the phone into search mode, the phone should find the device (make sure there are no other bluetooth phones nearby that could be interfering) and ask for the pass code (pin code) for the headset device.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
My Question Was .. When I am Trying To Pair a bluetooth headset to my device (sgh-x830), i always ask for a PIN code to pair with the bluetooth headset .. but i can't enter a PIN on bluetooth headset .. so can you tell me how do i pair a bluetooth headset to my sgh-x830
the model is N95 .. it got connected to my sgh-x830 but ask for PIN .. and i have already tired those 2 codes: 0000 & 1234.
please help me out
can you let me know where should i find the manufacturer name ? on this device ?
i have already done that .. but its asking for a PIN, i can enter it in my cell phone, but how come i type it on a bluetooth headset :s
Try 0000
