Question about Onkyo SKS-HT240 System
My subwoofer keeps blowing internal fuses?
The subwoofer that came with this system quit working. I opened it up and found 2 blown fuses. After replacing them, I plugged in the power cord, the sub made a brief noise, the standby/ power light came on for a second, and the two new fuses blew. Please help.
Thanks
  • 10,594 Answers
Please replace power amplifier chip in this sub-woofer to fix its issue, replace the chip with same number that would be written on it.
Check with local spare parts shops for power amplifier chip installed in your sub-woofer and if you have no experience working on circuit board, take the sub-woofer to local tv repair shop as they will replace it.
Hope this info will help you.
Thanks.
Posted on May 01, 2010
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
I have installed a 12" w7 and jl 1000/1 v2 amp. I was useing the bass knob untill i found out on the jl website that its not needed for this set up. I was haveing problems blowing 80 amp fuses so i went...
It is NEVER a good idea to increase the values of fuses . Chances are you have internally damaged your amp. The next time you are faced with this problem you need to find out why your amp is blowing fuses and not keep changing the value of the fuse.
Aug 20, 2010 | Jl Audio 12W7 Car Subwoofer
Unit does not power up. Opened unit and found fuse closest to power switch blown inside unit. Will replacing this fuse get my unit working again? If so, what would cause this fuse to blow? please help.
It is possible that the fuse was blown due to a surge and replacing it will resolve the problem, but I wouldn't expect it. Usually when the main fuse blows, the primary stage of the power supply has a problem and the replacement fuse will blow as well. This is not a cheap amp and I would suggest that it be checked by a service tech. A few quick measurements internally can determine the likely fault and should not cost too much as an estimate fee.
Please keep us posted.
Dan
Jun 22, 2010 | Sonance Sonamp 1250 12-Channel Amplifier
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
The unit won't power on at all.
You can try replacing it with any 10 amp fuse just to see what happens. If a new fuse keeps blowing out then you have a shorted power amplifier inside(they consist of transistor or a single chip). These device look normal most of the time short out with any visual indication. If you desolder the power amp chips(they are mounted against an aluminum heat sink to dissipate heat) and the fuse quit blowing then it is the problem.
Aug 11, 2009 | Samsung HT-TX72 Theater System
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Jun 01, 2008 | Acoustic Research AR1 Speaker
Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Feb 13, 2008 | Harman Kardon HKTS 7 System
Onkyo SKS-HT240 System Logo
314 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
