Question about GE Spacemaker WSLP1100D Top Load Washer
I have a GE spacemaker washer, gives message LO which means door open! won't fill nothing...
SOURCE: washer does not drain water
Make sure the drain hose is not kinked
Posted on Jul 20, 2008
SOURCE: GE Spacemaker Extra-Large Capacity Portable Washer
i was using a defective extension cord, the machine should trip when start it . and beep with no other message on the screen
Posted on Nov 09, 2008
SOURCE: GE washer: door won't unlock
We had the same problem and there is a wiring harness right at the door and I guess over time closing the door or the vibration from the spin cycle worked it loose. It would click and click like it was trying to lock but then the cycle would not start and it would just humm like it was trying to start the water. Make sure before you start to unplug the washer. The harness plug is on the side of the drum right at the door. If you take the bottom panel off and take the bottom two screws out and pull the panel out as much as you can you can see it there on the side. Just plug it back in and you are good to go.
Posted on Jul 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Washer won't drain
You might have a faulty lid switch mechanism or trash in the pump or both. MANUAL
Posted on Sep 09, 2009
oldmanewtoys
  • 414 Answers
SOURCE: GE Spacemaker top load washer U6 error code
level washer and do not overload capacity
Posted on Mar 09, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
GE washer model SWLP1100D error FF
Loss connection in the door motor safety circuit
Recommended to replace control
Nov 24, 2012 | GE Spacemaker WSLP1100D Top Load Washer
Ge washer "lo" light when lid is closed. and won't start after it has run before
"LO" means the washer's lid is not closed
What is the model number?
Oct 13, 2012 | Maytag Washing Machines
My Samsung Front Loader (WF410ANW) door lock won't open. I have replaced it 3 times. Every time it lasts about a week and I get the LO error message. I would like to know how to bypass the door lo
You can short the door switch and it will stay activated BUT the DANGER is that it will be available to be opened at any time specially after the water has loaded and if you accidentally open the water and clothes might flow out.
Jul 03, 2012 | Samsung WF410ANW Washer
My washer will not drain but everything else is working on it can u give me instructions?
most of the time it is the door switch that gets damage when the door slams. if its only fill with water but not turning then it is defently the door switch.
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Nov 08, 2008 | GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
829 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
