Question about Pride New Mobility Legend 4 Wheel Scooter
I have a pride mobility a scooter, maxima, when attempting to move forward just a clicking soound occurs no movement
  • 23 Answers
When mine does this it means she is not fully in gear. Try manually moving it back and forth a few inches and see if it clicks in.(Like moving the seat back in the car and it doesn't quite click in.) If it doesn't work take it fully back out of gear and try again. Mine is a pride victory 3 wheeler, to check the exact specs on yours follow the link below for a pdf of your user manual. See the bottom of page 34, (Troubleshooting)
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Maxima%20Owner%27s%20Manual.pdf
Hope this helps:).
Posted on May 06, 2010
Will it be hard or expense to replace the part to make go forward or reverse for my Pride Maxim scooter
if the batteries and motors are good
it may be the directional switch
Pride Maxima SC900 SC940 Parts
any parts on the parts list marked discontinued and found to be faulty
your repairer would need to source a used part
Oct 26, 2016 | Pride Health & Beauty
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
My scooter has started to make a clicking noise
hi , sounds like the brake is clicking which in this case is normal, sometimes as the brake wears the clicking get nosier. Can you please confirm where the clicking is coming from ??.
Regards
Rob
www.gewizrepairs.co.uk
Feb 27, 2014 | Pride Mobility Products Pride Mobility...
When i go forward or reverse i get a click the scooter does not move
Please check near the rear to ensure the the scooter is in gear. There should be a switch that needs to be moved up/down. Let me know if this is not the issue.
Good Luck!
Apr 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
From willaston auto electrics adelaide , customer brouht in a pride pathfinder 4 wheeler no forward or reverse movement, has power to volt gauge, horn works, any suggestions appreciated
neville the problem could be numerous things but lets try the simple ones first. a bad throttle pot or speed control pot can cause that problem. Both of those are located in the tiller console and that has to be removed to test them. You can ohms check both with power off and you can voltage check them with power on. You should get a smoth change in resistance as you turn th speed pot and as you move the throttle forward and reverse with power off. alsdo chech the connections in the tiller and remove the seat and battery cover and check the connections at the rear of the scooter sometimes just moving the wires can get it moving again but that won't help you locate the problem if you can't isolate the bad connection or bad wire. Scooters are tough to repair because of the many connectors that they have and the cables runnig front to rear that can cause problems especially with Pride scooters Good Luck I know I didn't give you much but I'm not fond of working on scooters Hope this Helps
Oct 12, 2010 | Pride Mobility Products Victory 9 Scooter...
I have a pride maxima 3 wheel the battery is charged push forward or reverse and all it does is click
Hi
I am Afraid your Potentiometer is Faulty , You need to Purchase a New one,'
It Just goes Click Click Click.
Aug 01, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a 2006 Pride Maxima. Problem comes and goes.
Hi Alex. Does this problem happen when you first turn on the scooter, or does it happen while you are riding the scooter.
It might possibly be that the speed lever ( wig wag ), is not correctly adjusted, or is worn.
Test the lever is correctly adjusted by sitting on the machine with the key on. Slowly move the lever in the forward direction, until you hear the brake click. Take note of how far the lever moved. Now move the lever in the reverse direction until you hear the brake unit click. The distance the lever moved, should be the same in both cases.
Also while you are driving your machine try moving the ends of the lever slowly up and down. If this makes the machine change speed erratically, then you probably need a new throttle pot, or speed lever assembly.
Does your machine show any fault codes or flashing LED's.
Hope this helps. Neil.
Jul 09, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
When turning the scooter on the system goes by it's self without pushing the handle to go forward
Sounds like the throttle mech has come loose, the lever is normally fixed to a pot with a long stem now if that's moved round it will power it self without any movement?
Apr 30, 2009 | Pride Mobility Legend 4 Wheel Electric...
No movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Apr 24, 2009 | Health & Beauty
No reverse and lost speed
that could be that you need a new pot for spped control bar, is there any up and down movement ? if yes that could be intermittant
Regards
GeWiz.
Jan 31, 2009 | Pride Mobility Products Pride Mobility...
Pride New Mobility Legend 4 Wheel Scooter Logo
302 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
