Question about Yahoo Messenger
Messenger keeps going off
My yahoo messenger keeps going off. I can't get it back on unless I reboot. What is causing this? And is there another way to get it on without having to reboot?
  • 304 Answers
Check your internet connection. that's the reason why it's going off. if not. reinstall your yahoo messenger application:)
Posted on May 02, 2010
I am unable to see the text messages entered by me in yahoo chat window the version yahoo 10 please help
SOMETIMES FILES GET CORRUPTED DURING A DOWNLOAD. GO TO CONTROL PANEL, ADD OR REMOVE PROGRAMS AND REMOVE YAHOO MESSENGER. REBOOT YOUR MACHINE. DOWNLOAD YAHOO MESSENGER FROM ANOTHER SITE AND INSTALL. THIS SHOULD FIX YOUR PROBLEM.
Feb 06, 2011 | Yahoo Messenger
Tip
Yahoo Messenger can't sign in - Unable to Connect to Yahoo Messenger
If you are having trouble signing into Yahoo Messenger you should read this article for some Tips and Tricks to get signed in.
There are a couple of things you will want to check first as they are common causes for being unable to sign in.
1) Make sure your internet is working. The easiest way to do this is by trying to visit other websites. After you have tried to visit some websites(it is best to test sites you have never been to before) and you confirm your internet is working but still unable to sign in, then continue to the other tips.
If you can't connect to other websites, you can read my tech article on Resolving Internet Connectivity Issues - "Can't connect to the Internet"
2) Sometimes, Yahoo Messenger will be down completely for everybody on a global level. This can be caused by problems Yahoo may be having or just general technical maintenance. Your only option if this is the case is to wait until it is over. You can confirm the Yahoo Messenger status at the Yahoo Messenger Support page.
If none of the above are the issue then continue below with Advanced steps
1) This tip is a recommendation from Yahoo Tech Support
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
2) In some cases you may have a local firewall or anti virus program that is blocking Yahoo Messenger or causing connectivity issues with it. You can try to disable any Firewalls you have and Anti Virus programs and see if you can now sign in. If so, then you will probably need to add exceptions in your firewall or anti virus program to allow Yahoo Messenger. If you need assistance with this step you will need to reach out directly to the company that makes the software. A google search by the application name or company name will bring you to the website where you can find help and contact information.
3) I have worked in Technical Support for many years and a simple but often overlooked step that works is to unistall or reinstall the program. There can be any number of causes for Yahoo Messenger program files to be corrupted or lost. A simple reinstall of Yahoo Messenger can get you back up and running. The best way to do this is through Control Panel in Windows.
-Go to Control Panel > Add and Remove Programs and find Yahoo Messenger in the program list.
-Click unistall and once removed go ahead and reboot your computer.
-Once rebooted, download Yahoo Messenger and install. Click here for the files.
-Once installed, reboot your computer again.
-Once rebooted try to launch Messenger and see if you can sign in.
4) At this point, if you have exhausted all the above steps, I recommend you contact Yahoo Messenger Tech Support directly. Click here for Tech Support.
I hope my article was informative. Check out some of my other Tips and Tricks by clicking on my Username at the top of this article and then going to "Tips" under my profile.
Regards,
G33k
Keywords
unable to sign in to yahoo messenger, can't connect to yahoo messenger, can't sign in to yahoo messenger, yahoo messenger not working, connect to yahoo messenger
on Jun 05, 2011 | Yahoo Messenger
Just lately Yahoo Messenger keeps dropping out. sometimes for a split second, then reboots itself. other times I need to restart YM
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 31, 2011 | Yahoo Messenger
I can does load my Yahoo messenger but can not use it. I keeps blinking in and out. How do I fix it?????
Jan 08, 2011 | Yahoo Messenger
How to use yahoo messenger using wifi in my blackberry 9700 phone
go to Options > Advanced > Applications and scroll the Yahoo 1) Messenger application and don't click on it, just scroll to it. Click Menu > Delete and remove the application.
(IF YOU HAVE NOT INSTALLED YAHOO MESS SKIP THE STEP 2 and GO TO 3 DIRECTLY)
2) Now, do a reboot: With the BlackBerry device powered ON, remove the battery a few seconds and then reinsert the battery to reboot.
3)Finally, use your BlackBerry browser to go to
blackberry.com/yahoo/messenger and download/install the Yahoo Messenger application again.
After installation and possibly another reboot, check your Instant Messaging Folder, or Downloads folder for the application.
Aug 31, 2010 | Cell Phones
I Have downloaded yahoo messenger 10 several times. Some times it lets me log in but if computer ever reboots then it no longer works. Cant remove yahoo messenger from add/remove programs and the downloads...
download yahoo messenger stand alone version from here
select your country then download
http://www.mydigitallife.info/2009/11/16/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 02, 2010 | Yahoo Messenger
My Yahoo Messenger keeps closing
my yahoo messenger keeps closing (crashinggraying out or sleeping not able to open to do instant messeging
Nov 28, 2009 | Yahoo Messenger
Recently when I try to logon my yahoo messenger acount, it keeps saying ''your account has been locked''! What does it mean? Maybe someone is trying to steal my password? Thanks for the help
Hi, locked accounts are quitecommon with Yahoo! To solve this problem, do the following.
1) Close and exit from Yahoo! Messenger completely
2) Log on to Yahoo! Web Messenger
3) Log off Yahoo! Web Messenger
4) Your account is now unlocked
5) Reboot your computer
6) Yahoo! Messenger should now work as expected
If this helped you then please help me by voting kindly, thank you
Oct 10, 2009 | Yahoo Computers & Internet
Yahoo Messenger 9 Vista Installation Problems
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Yahoo Messenger Logo
24 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
