Question about Royal 150MX Cross-Cut Shredder
Paper shredder jammed
Royal crosscut paper shredder jammed. Paper bin full and sucked up shred.
    Genius:
  • 1,218 Answers
Yes....this is a consumer model....NO BIN/BAG FULL INDICATOR....to keep costs down, you will just have to try to get the bin out a little at a time and slowly reach-in and "fish out the shredded paper...once you have enough out the bin will come out...hopefully the backed up paper has not jammed the machine and blown the PCB inside.....if it has give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Aug 31, 2010
  • M BASSI Jun 27, 2013
    HOW TO RESET AND CLEAR TEETH W/ WHAT tool HELP ME ASAP
Paper jam both forward and reverse are not shredding it is a clump of papers and I can't get it lose
Sound like a serious jam up. Try a sharp small screw driver to flick out jammed paper and try rotating by hand. Caution ensure it is unplugged and use gloves to protect from sharp edges. With the clump of paper try a LITTLE water to soften the clump. Good luck.
Aug 25, 2013 | Royal 1840mx Crosscut Shredder
How do I oil my royal crosscut shredder 1610X
To oil your shredder, squirt some shredder oil onto a piece of paper (don't completely soak the paper) that you wish to shred & feed this paper through your shredder.
Feb 10, 2011 | Royal VF1000MX Shredder
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
How do you empty the drawer
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin. Work the bin out a little at a time to get the paper out.
Aug 13, 2010 | Royal PX1000MX Shredder
How do I remove the wastebasket?
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin. Try working the bin out a little at a time and trying to "fish" the paper out.
Jul 27, 2010 | Royal PX1000MX Shredder
How do I empty a Royal PX1000MX?
Jun 30, 2010 | Royal Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Royal 150MX Cross-Cut Shredder Logo
437 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
