Question about Philips GoGear SA5285/37 Digital Media Player
I have a philips gogear sa5285/02 it is just loading up to the gogear logo and freezing it will not pick up on my computer i have tried to reset but nothing please can you give any advice
  • 820 Answers
All support for the SA5285/02 is on next page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA5285/02&slg=en&scy=GB
When the reset was to no avail, see next help information:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview.pl?ctn=SA5285%2F02&dct=QAC&new_tmpl=1&refdisplay=PAV_GENERAL_HANGUP_1&refnr=0073626&scy=GB&slg=ENG
Try resetting from step 1 or try following steps:
In step 2 and 3 the player's content will be deleted !
When needing more help, just add a comment in this reply.
Posted on May 01, 2010
I have a philips gogear 8gb freezes up several times a hour
Unfortunately the GoGear HDD series is totally incompatible with Windows Vista and Windows Media Player 11. It will work for a while, and then behave exactly as you described. Solution: You will need to uninstall your GoGear software, rollback to Windows Media Player 10, reinstall the GoGear software, update the firmware on your player, and even then the damage may already be done (IMO, it is more trouble than this player is worth). You can read about the warnings on Philips website.
-Tha Mp3 Doctor
Mar 18, 2009 | Philips GoGear HDD1830 MP3 Player
Loading Problem - Results in Frozen Gray Screen
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 13, 2009 | Philips GOGEAR SA6045 MP3 Player
My GoGear 8G wont come on
1. On you computer, ensure that Philips Device Manager is running.
2. Turn your mp3 player on (it should freeze at the Loading or GoGear Screen).
3. Plug in the mp3 player to your USB/Charger cable (ensure it is connected to the USB port on your computer), and then perform a soft reset (Power switch down and Volume up button simultaneously).
4. Let go of the other buttons as soon as the player resets. Hold the Volume down button until the player comes on. The player will be recognized by Philips Device Manager and will report a problem (and will allow you to repair it). Windows will also recognize it as a Mass Storage Device.
edit:
video: http://video.google.com/videoplay?do...56814975105076
Jan 15, 2009 | Philips GoGear SA5285/37 Digital Media...
My MP3 Is Frozen
Unfortunately, this GoGear did not come with a recovery method. You can go to www.usasupport.philips.com and enter in your model #. Go to "software & drivers" section. see if it has a download for device/firmware manager - but I believe this is the one SA model that did not have one. Click on the "Repair" tab if you are able to load the software.
Jul 05, 2008 | Philips GoGear SA178 MP3 Player
When i turn on the philips gogear it says philips,gogear,updating and then it jams
This player has an issue that the latest firmware fixes, re: constant freezing during updating. If you can just get the computer to recognize the player, and load the firmware update then you should be fine. The firmware update should load when you go to the "Update" button on the latest Device Manager (the version of the Device Manager from Philips' website, not from the install CD).
If the computer is not recognizing the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jun 09, 2008 | Philips GOGEAR SA6045 MP3 Player
Frozen screen
reset the gogear pres the power and volume + at same time
Apr 19, 2008 | Philips GoGear HDD6330 MP3 Player
GoGear 8Gb
You need a firmware upgrade.
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Feb 18, 2008 | Philips GoGear HDD1850 MP3 Player
I need Help
I would recommend you to get the firmware upgrade on the device..that usually happens when your device firmware is corrupted...If after you done a firmware upgrade your device doenst work properly contact the manufacturer...
Thank You
Computerrep
**Rate accordingly..
Jan 01, 2008 | Philips HDD1630 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
462 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
