Question about Panasonic Cameras
Failure to close when turned off
The camera suddenly failed to close when turned off. Then, when turned on, it closed completely, then opened in a few seconds. A message came up with focus problem. When turned on, it say ''please turn camera off and then on again'' but when I do so it goes off without the lens closing.I took the battery out and replaced it without improvement When I tried to take a picture the camera opened but there was a stuttering sound and the message to turn the camera off and then on. Could there be a softwear problem, or perhaps dirt has gotten in the mechanism? The camera is relatively new.
  • 1 more comment
  • mikeslade143 May 01, 2010
    trying what 1st expert suggested not helpful. Would try another. Camera does not respond to any command in the on mode.When attempting to turn off, then on, the lens does not retract when turned off. When turned back on the lense retracts briskly and completely and the cover deploys - then it comes out again but probably not enough, and it "stutters", and I get a "system error (focus)"
    Dear Guru: is possible that there is some grit in the mechanism so that it will not extend completely, but goes to almost the correct extension and then won't go further? Also, we are not home and do not have a charger. Is there any chance that the problem will be corrected with a fully charged battery (I doubt this but thought I'd ask)?
    any chance it is caused by dirt in the mechanism? Or by a low battery?
  • 10,319 Answers
You have a faulty capacitor in this camera
If fairly new have it repaired
Posted on May 01, 2010
    President:
  • 1,194 Answers
The number one reason for this message is the lens being stuck. By the lens moving when you toggle the power seems to indicate that it is not stuck .
You could try giving the lens a GENTLE nudge on the edges when you turn the camera off to see if it retracts when it is supposed to.
There should be a reset in the menu somewhere which you could try too.
Also, please update your camera's software.
Good Luck and have a nice day.
Lens cover stuck
Get canned air and gently blow on diaphragm while opening and closing.
Jul 11, 2014 | Nikon Coolpix 4800 Digital Camera
My exilim camera is taking black pictures. Two days ago it was fine and all of a sudden when I turn it on the display screen and previous pictures are dark. When I take a picture or video now it is just...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 28, 2011 | Casio Cameras
When i turn the camera on and switch to picture mode the screen is completely black, and if i take a picture, the picture turns out completely black
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A in the link, by gently flicking with your fingertip as described in the article.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
I have a Canon PowerShot S2 IS and all of a sudden I cannot get an impage in view finder nor the flip lens. Any suggestions?
A stuck shutter is another common failure mode for digital cameras, but especially for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 08, 2010 | Canon Cameras
Viewing screen is completely blank and will not take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
When I turn on my Canon PowerShot S2 IS camera and set it to shoot mode, the screen is black. A while back, I was able to get the screen to show by toggling with the camera and constantly turning it on and...
For your model camera, pay close attention to the "UPDATE" at the beginning of the above linked article. Who knows, maybe Canon is actually fixing this problem?
Oct 15, 2009 | Canon PowerShot S2 IS Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
G-2 Power Shot no longer closes completely
I had the same problem with my G1 and it seems that with time and with usage of the cam it ends up doing this, i solved my problem moving it back and forth but slowly and then try to push it softly ..then turn it of and on ..and it will go in.., suddenly it will happen the same thing again and again.. because mine still does that some times
Apr 02, 2007 | Canon PowerShot G2 Digital Camera
Cameras Logo
19 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
