I get 3 beeps when i try to turn the pc on - Computers & Internet
  • 55 Answers
3 beeps usually means you have a bad ram stick, but it could be different depending on the manufacturer of your machine.
Posted on Mar 25, 2008
SOURCE:
MONITOR BLACK PC BEEPS AND BEEPS CONTINUOSLY
Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem.
depending on the type of beep your motherboard makes you can get to know what your problem is. below are beep code links for various BIOS manufacturers. check yours.
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
http://pcsupport.about.com/od/fixtheproblem/tp/award-beep-codes.htm
http://pcsupport.about.com/od/fixtheproblem/tp/phoenix-beep-codes.htm
Most likely you have a faulty ram, try to use a friends ram to see if that works. make sure that your friends ram is compatible with your computer.
Jan 24, 2014 | Sony VAIO Digital Studio PCV-RX660 PC...
T6520 emachine won't turn on, lights and fan work. Beep code
Hi, you are having a problem with your add on cards, try to pull out everything that you have add on to you PC, then try to put 1 by 1 and try to turn on. If it beep once its OK, but if it's continue then the add on cards are the defective.
Oct 08, 2012 | E-Machines eMachines Desktop PC
When i turn on mt pc it beeps 9 times and noyhing
What you are hearing is a "post error code".
The codes vary depending on the manufacture.
For instance if you have a Dell 2400 trying searching the web for "Dell 2400 post beeps".
Although I believe 9 beeps is commonly a CMOS error.
If so, you can try clearing the CMOS.
You will have to know how to get to the Computer BIOS screen to set things if you do clear/reset the configuration.
Jul 20, 2010 | Dell Dimension 4550 PC Desktop
Loud beeping noise when trying to turn laptop on
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
Nov 07, 2009 | HP Pavilion dv9000z Notebook
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with [email protected]
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
When turned on,makes long buzz, no video,rest of pc still runs
Do you mean beep? Beeping may occur due to RAM corruption (indicated by three long beeps). Failure of input or output devices may also cause beeping. first unplug the RAM, if the same beep continues, then the culprit is RAM. if not,then replug it and unplug the KeyBoard. do the same with the rest of the I/O devices. Also try to put ur processor in ur frens PC, and vice versa, then u'll know if ur processor or the motherboard is not working.
Oct 11, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Beep Beep Beep
How many beeps? There should be a sequence of beeps. Are they all the same, or are some short beeps and some long? Please clarify so I may help you further.
May 22, 2008 | Asrock K7S41GX Motherboard
Troubleshooting
are u getting any beep message ? let me know the model and the beep tone that you get, if you don't get any beep try changing ram if you have VGA card installed try changing that.
Dec 06, 2007 | Compaq Presario SR1000T (568657) PC...
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
Open Questions:
Computers & Internet Logo
77 people viewed this question
Ekse
Alun Cox
