Question about Troy Bilt 5.5hp Self Propelled Mower
My honda engine will run for a few seconds then dies. drained the bowl, thought it might be moisture in tank, and it still wont stay running.
  • 247 Answers
Two possibilities here.
Most likely at this time of year is that the fuel is contaminated and that you've got a fresh slug of water in the bowl
Try draining the bowl again, while having a good look at what comes out first:
If it's oily water (comes out slowly in big drops that stay bunched up when they land. If you put a bit on your finger and bring it to your nose, it smells unpleasantly oily. May contain rust coloured blobs of microbial contamination), then you've got a tank of contaminated fuel.
If you get petrol straight away (just runs out, spreads out over every surface it touches and makes the place absolutely reek of petrol the moment it comes out) then perhaps water isn't the problem.
If you get water repeatedly, then you need to drain the tank and refill with fresh fuel.
The other thing that would make the engine cutout after a while is if the engine is sucking fuel out the bowl faster than it's being replaced, which is likely to be a blockage issue.
Try draining the whole fuel system, removing the bowl, cleaning the insides of it out, blowing through the drillings on the bolt that held the bolt on and cleaning out any snotty stuff that's blocking up the float-operated inlet valve exposed when you removed the bowl. Reassemble carefully (if the bottom of the bowl is shaped, make sure you put it on so the float is free to move) and take this opportunity to refill with fesh fuel.
A.
Posted on May 01, 2010
I have the same problem runs good for a minute then stalls i have drained the gas both in the tank and bowl i still have the problem i just bought a new carb started right up then stalled in a minute same problem I'm stumped
Posted on Jul 16, 2011
Shredder won't stay running without starting fluid
Water being heavier than gasoline is likely to be in the carburetor. If a bowl type carburetor, remove the bowl and clean. Allow the fuel to run for a few seconds to clear the water from the lines.
If a diaphragm type carburetor, remove the diaphragms and allow the fuel to clean the lines.
Jan 23, 2017 | Briggs Garden
Gas will not flow from tank to motor while running
Everybody had a crack at this problem, another thing would check is these engines sometimes have a primary fuel filter inside the tank itself. Drain the fuel and gently blow compressed air back through fuel line towards tank then rinse the tank out with fuel, refill and try run engine again
Aug 07, 2014 | Honda 8 HP Engine
Masport 635 starts, revs up once, and dies. Will start again a few pulls later. Carb diaphragm has been replaced with no change. Could it be ignition? Thanks.
follow this steps and fix it. God bless you
Carburetor
If the lawn mower engine stops after a few seconds, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Carburetor Kit
If the engine stops after a few seconds it may not be getting enough fuel. The engine needs air, fuel and spark to maintain operation. The carburetor has two inputs, fuel from the gas tank and air through the air filter. The carburetor is designed to mix the air and fuel in a consistent ratio so that the engine can run continuously. If the carburetor is not getting enough air or fuel, or if the fuel is blocked inside the carburetor the engine stops after a few seconds. Rebuild the carburetor with this carburetor kit.
Gas Cap
If the lawn mower engine stops after a few seconds and then stops running, the gas cap might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it should be replaced.
Gas Cap with Gauge
If the lawn mower engine stops after a few seconds and then stops running, the gas cap with gauge might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it has to be replaced.
Old or Bad Gasoline
If the lawn mower stops after a few seconds, the carburetor might be clogged or have old or bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This old or bad fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old or bad fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Spark Plug
If the lawn mower engine stops after a few seconds the spark plug might be defective. All small engines have an ignition coil. The coil is the device that provides spark for the spark plug(s). If the coil is bad there won't be spark to the plug(s). The coil is essentially a small, induction generator. It is mounted next to the flywheel. The flywheel has one or more strong, embedded magnets. As the flywheel spins, the magnet(s) zip past the induction coil, this action of a magnet passing past a coil induces a voltage. Depending on the design of the coil and the strength of the magnets, a stronger or weaker spark can be created and delivered to the spark plug(s). Each time the flywheel spins around a spark is generated. The best way to test a spark plug is to use a spark plug tester. The spark plug should have a strong, visible spark between the electrodes when the engine is cranking. If it doesn't, replace it.
Nov 13, 2013 | Garden
GX (or GTX, not sure) 360, 5.5 hp Honda engine on a pressure washer; engine will start and run perfect for about 30-45 seconds, no smoke or rough idle during that time, then engine dies and will not start...
Try draining all the fuel from the tank and carburetor. Replenish with fresh fuel. Try using an additive that keeps the fuel fresh longer and will displace some moisture. Good luck.
Mar 05, 2011 | Honda Garden
My dirt bike did work but has not been used for 1yr.. tried to start it today and it sounds like it wants to but doesne, what can i do
I would check to see if moisture has built up in the gas tank --- over time condensation forms in a ( not full ) fuel tank, especially in colder enviroments. one thing that you can try is drain the carburetor bowl and add some gas additives to the tank ( or drain the tank and start out with some new gas ) --- but drain the carb bowls and try to start and run again.. there also might be some debris in the carb bowl that is blocking the jet,, ( remove the bowl and spray with carb cleaner ).
c...
Dec 29, 2010 | 2002 Honda XR 200
My 2008 kfx450r wont stay running. when i finally get it started i can pin the throttle wide open for a few seconds but it dies like its not getting fuel please help any info i will take
ALWAYS have a fire extinguisher on hand when working on carburetors.
Open the petcock, (gas valve), and drain 1/2 cup of gas from the tank. Did the fuel flow freely? Is there any water or trash in the cup?
Drain the carburetor. There should be a screw on the lower right side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Check the float height. The fuel level in the bowl may be low. Bend the tang (in the center of the float) downward to raise the fuel level. EASY, a little bend goes along way.
Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Jul 05, 2009 | 2006 kawasaki KX 450 F
Engine cut out at speed.
This sounds like some water in the float bowl. Drain the carb using the screw on the lower side of the bowl or the plug in the bottom of the bowl, depending on which carb model you have. Drain a cup of gas from the tank as well. Moist air can condensate in the tank. that is where the water comes from.
Jun 22, 2009 | 2006 Honda CBR 125 R
Wont start after 6 mos. I changed the spark plug, drained & added fresh gas, checked the fuel filter... Kicks over fine. Ran for 4 seconds, then it died. Always ran & started great before.
With a new plug and fresh gas it should start. Check to make sure there isn't a kill switch turned off or that the gas petcock from the tank to the carb is on.
How did you check the fuel filter? Disconnecting it from the fuel line that goes to the carb is the best way, making sure the gas is turned on under the tank. Bleed off a little gas into a can or something just to make sure the filter isn't plugged.
The last thing I'd do is take off the air filter and spray a little starting fluid in the carb. It may start and run several times if there is old gas in there somewhere. Remember the bowl on the carb is probably still full of old gas. After some fresh fuel reaches the plug it should start and continue to run.
(You might drain the bowl on the carb of ols gas before you go any further)
Sirwriter
May 22, 2009 | 2006 Honda Civic Hybrid
My lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Mar 29, 2009 | Garden
My car wont stay running
Does the engine die as soon as you release the key, or does it run for a couple of seconds after you release the key and then die? If it dies as soon as you release the key, try holding the key for a few seconds and see if it will stay running as long as you are holding the key (the starter will make a grinding sound while holding the key but won't hurt anything). If it stays running while you hold the key then dies when you release it, that indicates that the ignition switch is bad.
Jul 01, 2008 | 1992 Honda Accord
Troy Bilt 5.5hp Self Propelled Mower Logo
560 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
