Question about Sanyo Vpc-s1070w Digital Camera
COMPUTER WONT RECOGNIZE COMPUTER AND I CANNOT LOCATE MY DISK TO DOWNLOAD THE DRIVER AGAIN
    Brigadier General:
  • 11,967 Answers
Use a card reader for downloading pics.
Posted on May 01, 2010
My external hard drive got a virus had to reformat now computer wont recognize it
I am taking for granted that you are using Windows, not sure which version ( XP , 7, 8 , 8.1 )
and if I am correct, but your computer does not recognize the drive, make sure the usb port is one that will give power to the external drive. You should use USB2 or if available USB3. Those are powered.
Click the Search feature for the particular version of Windows you are running and search for "Disk Management"
Look for the partition of the external drive you are using. It will be given a letter other than C: drive. May be D: E: F: etc etc etc. Sometimes your optic drive is the D: drive, you may need to purchase a program like Everest Ultimate to locate ALL your items on the MOBO.
If your able to find the External in Disk Management, you should be able to format it, rename it, change its functions, etc etc.
Good Luck
Oct 21, 2013 | Toshiba 120GB USB 2.0 Portable External...
Computer wont start
is it your computer or just your hard drive that wont start
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 05, 2012 | Seagate Expansion 500 Gb Usb 3.0 Portable...
My Computer wont recognize my Samsung YP-P3
this could be a driver problem
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
http://download.cnet.com/samsung-yp-300/3000-18493_4-69368.html
hope it helps
Apr 15, 2012 | Samsung YP Audio Players & Recorders
My computer won't recognize new SanDisk sansa clip. My computer won't read CDs, thus won't read the installation disk. Is there anyway to download what's on the CD so the computer will recognize the MP3...
Driver:
http://www.sandisk.com/sandisk-support/driver-download-wizard
Manual:
http://www.sandisk.com/sandisk-support/warranty-and-user-guides
Sansa Media Converter:
http://www.megaupload.com/?d=3IPZO6Q0
Dec 28, 2010 | SanDisk Sansa Clip MP3 Player
There is no network on it
Step 1: Physically install the network adapter.
Step 2: Boot the computer. Wait for Vista to recognize the new hardware. Once it prompts you to locate the driver. Click Locate And Install Driver Software (Recommended).
Step 3: If Vista fails to locate the drivers internally or online, it will prompt you to insert the Driver Disk.
Step 4: Once the disk is inserted, Vista will locate the driver from the CD and install it. Click Next to continue.
Step 5: After the drivers are installed, Vista will tell you the card has installed properly and is ready to use. You should not have to reboot.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | D-Link AirPlus G DWL-G122 802.11g/b...
Trying to install printer to new computer unable to locate printer model
please use the disk of the printer. maybe the new computer won't recognize the printer driver.
Mar 05, 2010 | Canon MX300 Office All-In-One Printer
My new epson stylus NX110 wont download into my computer it said it needs a driver
You need to install drivers to have the operating system recognize the device. The unit should have come with a disk. If not, you can go to the epson site and download the driver, and other software for your device.
Dec 17, 2009 | Epson Computers & Internet
Installation
If the card is installed correctly, the computer should recognize it at start up and will begin the "Found new hardware" wizard. If it cannot locate the driver automatically, then you will need to download the proper driver (Google it) and install.
Dec 11, 2009 | Cnet Pro200 Network Adapter
My windows xp does not recognize my garmin200
Go to the Garmin site and download you USB driver. Install the driver with out the GPS connected. Aftter the USB driver is installed reboot you computer and then connect the GPS. Let us know if that works.
Dec 16, 2008 | Garmin nuvi 200W GPS Receiver
Windows does not recognize new My Book external Hard Drive.
simply it needs a driver...u must install the driver of ur external hard drive in order windows can recognize it...
chaw
Jun 03, 2008 | Computers & Internet
Sanyo Vpc-s1070w Digital Camera Logo
51 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
